How to get VBAT and internalReference voltage?
How to get VBAT and internalReference voltage? I tried the following, without success:
public class VBAT
    private AdcController adcController3;
    private AdcChannel vbat;
    private AdcChannel internalReferenceVoltage;
    private IntPtr enable_reg;
    public VBAT()
        adcController3 = AdcController.FromName(SC20260.Adc.Controller3.Id);
        vbat = adcController3.OpenChannel(SC20260.Adc.Controller3.VBAT);
        internalReferenceVoltage = adcController3.OpenChannel(SC20260.Adc.Controller3.InternalReferenceVoltage);
        enable_reg = (IntPtr)((0x40000000U + 0x18020000 + 0x6300 + 8));
    public float Voltage
        get
            int enable_val = Marshal.ReadInt32(enable_reg);
            enable_val |= (1 << 24);
            Marshal.WriteInt32(enable_reg, enable_val);
            // The VBATEN bit of the ADCx_CCR register is used to switch to the battery voltage. As the
            // VBAT voltage could be higher than VDDA, to ensure the correct operation of the ADC, the
            // VBAT pin is internally connected to a bridge divider by 4.
            float voltage = (float)(vbat.ReadValue() * InternalReferenceVoltage / 65535.0 * 4.0);
            enable_val &= ~(1 << 24);
            return voltage;
    public float InternalReferenceVoltage
        get
            enable_val |= (1 << 22);
            float voltage = (float)(internalReferenceVoltage.ReadValue() * 3.3 / 65535.0);
            enable_val &= ~(1 << 22);
            return voltage;
static void Main()
    VBAT vBat = new VBAT();
    do
        Debug.WriteLine($"InternalRefeference = {vBat.InternalReferenceVoltage:f1} V, VBAT = {vBat.Voltage:f1} V");
        Thread.Sleep(1000);
    } while (true);
