I’ve tried FAT32 & exFAT.
I’ve tried 2GB cards, 32GB, old cards, brand new cards.
But ManagedFileSystem ALWAYS says FileResult.NoFileSystem
I know it’s talking to the SD card. I’ve stepped through the ManagedFileSystem code.
CheckFileSystem returns 2:Valid BootSector but not FAT
FindVolume() cannot find a FAT file system
Any suggestions ?
What device are you using, can you push simple code? Some API seems not from TinyCLR.
Mike
#3
MBR and FAT32 should do it.
I’m running code from your examples on a PICO.
No other devices attached except an SD Card on SPI1 and PH0.
internal class Program
private static SpiController _SpiController;
private static GpioPin _chipSelect;
private static ManagedFileSystem _managedFileSystem;
private static byte[] dataWrite = new byte[5] { 6, 7, 8, 9, 10 };
static void Main()
_SpiController = SpiController.FromName(SC13048.SpiBus.Spi1);
_chipSelect = GpioController.GetDefault().OpenPin(SC13048.GpioPin.PH0);
_managedFileSystem = new ManagedFileSystem(_SpiController, _chipSelect);
_managedFileSystem.Mount();
var fileWrite = _managedFileSystem.OpenFile(@"\TEST.txt", FileMode.Write | FileMode.CreateAlways);
_managedFileSystem.WriteFile(fileWrite, dataWrite, 0, (uint)dataWrite.Length);
_managedFileSystem.FlushFile(fileWrite);
_managedFileSystem.CloseFile(fileWrite);
Debug.WriteLine(_managedFileSystem.DriveFormat);
Debug.WriteLine("Volumme: " + _managedFileSystem.VolumeLabel);
Debug.WriteLine("Total Size: " + _managedFileSystem.TotalSize);
Debug.WriteLine("Free: " + _managedFileSystem.TotalFreeSpace);
Program fails within ManagedFileSystem : Extensions.cs
The references to CheckFileSystem() and FindVolume() are functions within
ManagedFileSystem : FATFileSystem.cs
I think I figured it out.
If I slow down the SPI interface to 100kHz, it can find the FAT file system.
So … I must have a noisy SPI bus.
Mike
#6
Mike,
That table ( Single Board Computers (ghielectronics.com)) has errors.
I got the SD Card working on the PICO. Had to slow down the SPI bus.
Don
Mike
#8
Ah! I assumed since it was on the Internet it was true.
Ha ! That’s pretty funny. What did we do years ago without the Internet ??!!
The examples at TinyCLR Tutorials (ghielectronics.com) have really been a life saver. Downloading the source code libraries from GHI Electronics (github.com) and then reading through them thoroughly have also been a huge help !
The big clue here was the Managed File System example at Software Utility Drivers (ghielectronics.com) shows an SD Card connected to a Pico.
Too bad the Managed File System doesn’t support FileStreams. If I get some free time, maybe I’ll add that!
Sure do love the TinyCLR platform.
SC13 doesn’t support SD mean not support native SD. When you use SPI to talk SD this is different thing.
