There is a bunch of metadata in a BMP file, so it’s not clear how to parse out just the bits i need to make the 64 bit array. I ended up just hard coding the numbers I needed. Here is the solution if anyone else needs double numbers (like for a clock):
public class DoubleNumberBitmapProvider : IBitmapProvider
public static byte[] Number00 = new byte[] { 0xee, 0xaa, 0xaa, 0xaa, 0xaa, 0xaa, 0xee, 0x00 };
public static byte[] Number01 = new byte[] {0xe4, 0xac, 0xa4, 0xa4, 0xa4, 0xa4, 0xee, 0x00};
public static byte[] Number02 = new byte[] {0xee, 0xa2, 0xa2, 0xae, 0xa8, 0xa8, 0xee, 0x00};
public static byte[] Number03 = new byte[] {0xee, 0xa2, 0xa2, 0xae, 0xa2, 0xa2, 0xee, 0x00};
public static byte[] Number04 = new byte[] {0xea, 0xaa, 0xaa, 0xae, 0xa2, 0xa2, 0xe2, 0x00};
public static byte[] Number05 = new byte[] {0xee, 0xa8, 0xa8, 0xae, 0xa2, 0xa2, 0xee, 0x00};
public static byte[] Number06 = new byte[] {0xee, 0xa8, 0xa8, 0xae, 0xaa, 0xaa, 0xee, 0x00};
public static byte[] Number07 = new byte[] {0xee, 0xa2, 0xa2, 0xa2, 0xa2, 0xa2, 0xe2, 0x00};
public static byte[] Number08 = new byte[] {0xee, 0xaa, 0xaa, 0xae, 0xaa, 0xaa, 0xee, 0x00};
public static byte[] Number09 = new byte[] {0xee, 0xaa, 0xaa, 0xae, 0xa2, 0xa2, 0xee, 0x00};
public static byte[] Number10 = new byte[] {0x4e, 0xca, 0x4a, 0x4a, 0x4a, 0x4a, 0xee, 0x00};
public static byte[] Number11 = new byte[] {0x44, 0xcc, 0x44, 0x44, 0x44, 0x44, 0xee, 0x00};
public static byte[] Number12 = new byte[] {0x4e, 0xc2, 0x42, 0x4e, 0x48, 0x48, 0xee, 0x00};
public static byte[] Number13 = new byte[] {0x4e, 0xc2, 0x42, 0x4e, 0x42, 0x42, 0xee, 0x00};
public static byte[] Number14 = new byte[] {0x4a, 0xca, 0x4a, 0x4e, 0x42, 0x42, 0xe2, 0x00};
public static byte[] Number15 = new byte[] {0x4e, 0xc8, 0x48, 0x4e, 0x42, 0x42, 0xee, 0x00};
public static byte[] Number16 = new byte[] {0x4e, 0xc8, 0x48, 0x4e, 0x4a, 0x4a, 0xee, 0x00};
public static byte[] Number17 = new byte[] {0x4e, 0xc2, 0x42, 0x42, 0x42, 0x42, 0xe2, 0x00};
public static byte[] Number18 = new byte[] {0x4e, 0xca, 0x4a, 0x4e, 0x4a, 0x4a, 0xee, 0x00};
public static byte[] Number19 = new byte[] {0x4e, 0xca, 0x4a, 0x4e, 0x42, 0x42, 0xee, 0x00};
public static byte[] Number20 = new byte[] {0x4e, 0xc2, 0x42, 0x42, 0x42, 0x42, 0xe2, 0x00};
public static byte[] Number21 = new byte[] {0xe4, 0x2c, 0x24, 0xe4, 0x84, 0x84, 0xee, 0x00};
public static byte[] Number22 = new byte[] {0xee, 0x22, 0x22, 0xee, 0x88, 0x88, 0xee, 0x00};
public static byte[] Number23 = new byte[] {0xee, 0x22, 0x22, 0xee, 0x82, 0x82, 0xee, 0x00};
public static byte[] Number24 = new byte[] {0xea, 0x2a, 0x2a, 0xee, 0x82, 0x82, 0xe2, 0x00};
public static byte[] Number25 = new byte[] {0xee, 0x28, 0x28, 0xee, 0x82, 0x82, 0xee, 0x00};
public static byte[] Number26 = new byte[] {0xee, 0x28, 0x28, 0xee, 0x8a, 0x8a, 0xee, 0x00};
public static byte[] Number27 = new byte[] {0xee, 0x22, 0x22, 0xe2, 0x82, 0x82, 0xe2, 0x00};
public static byte[] Number28 = new byte[] {0xee, 0x2a, 0x2a, 0xee, 0x8a, 0x8a, 0xee, 0x00};
public static byte[] Number29 = new byte[] {0xee, 0x2a, 0x2a, 0xee, 0x82, 0x82, 0xee, 0x00};
public static byte[] Number30 = new byte[] {0xee, 0x2a, 0x2a, 0xea, 0x2a, 0x2a, 0xee, 0x00};
public static byte[] Number31 = new byte[] {0xe4, 0x2c, 0x24, 0xe4, 0x24, 0x24, 0xee, 0x00};
public static byte[] Number32 = new byte[] {0xee, 0x22, 0x22, 0xee, 0x28, 0x28, 0xee, 0x00};
public static byte[] Number33 = new byte[] {0xee, 0x22, 0x22, 0xee, 0x22, 0x22, 0xee, 0x00};
public static byte[] Number34 = new byte[] {0xea, 0x2a, 0x2a, 0xee, 0x22, 0x22, 0xe2, 0x00};
public static byte[] Number35 = new byte[] {0xee, 0x28, 0x28, 0xee, 0x22, 0x22, 0xee, 0x00};
public static byte[] Number36 = new byte[] {0xee, 0x28, 0x28, 0xee, 0x2a, 0x2a, 0xee, 0x00};
public static byte[] Number37 = new byte[] {0xee, 0x22, 0x22, 0xe2, 0x22, 0x22, 0xe2, 0x00};
public static byte[] Number38 = new byte[] {0xee, 0x2a, 0x2a, 0xee, 0x2a, 0x2a, 0xee, 0x00};
public static byte[] Number39 = new byte[] {0xee, 0x2a, 0x2a, 0xee, 0x22, 0x22, 0xee, 0x00};
public static byte[] Number40 = new byte[] {0xae, 0xaa, 0xaa, 0xea, 0x2a, 0x2a, 0x2e, 0x00};
public static byte[] Number41 = new byte[] {0xa4, 0xac, 0xa4, 0xe4, 0x24, 0x24, 0x2e, 0x00};
public static byte[] Number42 = new byte[] {0xae, 0xa2, 0xa2, 0xee, 0x28, 0x28, 0x2e, 0x00};
public static byte[] Number43 = new byte[] {0xae, 0xa2, 0xa2, 0xee, 0x22, 0x22, 0x2e, 0x00};
public static byte[] Number44 = new byte[] {0xaa, 0xaa, 0xaa, 0xee, 0x22, 0x22, 0x22, 0x00};
public static byte[] Number45 = new byte[] {0xae, 0xa8, 0xa8, 0xee, 0x22, 0x22, 0x2e, 0x00};
public static byte[] Number46 = new byte[] {0xae, 0xa8, 0xa8, 0xee, 0x2a, 0x2a, 0x2e, 0x00};
public static byte[] Number47 = new byte[] {0xae, 0xa2, 0xa2, 0xe2, 0x22, 0x22, 0x22, 0x00};
public static byte[] Number48 = new byte[] {0xae, 0xaa, 0xaa, 0xee, 0x2a, 0x2a, 0x2e, 0x00};
public static byte[] Number49 = new byte[] {0xae, 0xaa, 0xaa, 0xee, 0x22, 0x22, 0x2e, 0x00};
public static byte[] Number50 = new byte[] {0xee, 0x8a, 0x8a, 0xea, 0x2a, 0x2a, 0xee, 0x00};
public static byte[] Number51 = new byte[] {0xe4, 0x8c, 0x84, 0xe4, 0x24, 0x24, 0xee, 0x00};
public static byte[] Number52 = new byte[] {0xee, 0x82, 0x82, 0xee, 0x28, 0x28, 0xee, 0x00};
public static byte[] Number53 = new byte[] {0xee, 0x82, 0x82, 0xee, 0x22, 0x22, 0xee, 0x00};
public static byte[] Number54 = new byte[] {0xea, 0x8a, 0x8a, 0xee, 0x22, 0x22, 0xe2, 0x00};
public static byte[] Number55 = new byte[] {0xee, 0x88, 0x88, 0xee, 0x22, 0x22, 0xee, 0x00};
public static byte[] Number56 = new byte[] {0xee, 0x88, 0x88, 0xee, 0x2a, 0x2a, 0xee, 0x00};
public static byte[] Number57 = new byte[] {0xee, 0x82, 0x82, 0xe2, 0x22, 0x22, 0xe2, 0x00};
public static byte[] Number58 = new byte[] {0xee, 0x8a, 0x8a, 0xee, 0x2a, 0x2a, 0xee, 0x00};
public static byte[] Number59 = new byte[] {0xee, 0x8a, 0x8a, 0xee, 0x22, 0x22, 0xee, 0x00};
#region IBitmapProvider Members
public byte[] GetBitmap(string key)
var number = int.Parse(key);
if (number < 0 || number > 60)
throw new ArgumentException("Number must be between 0 and 60.", "key");
if (key.Length == 1)
key = "0" + key;
return GetType().GetField("Number" + key).GetValue(this) as byte[];
#endregion
