I’m trying to figure out how much memory my application is using on my Raptor board but I don’t really understand how to interpret the information that VS2013 gives me. I’m particularly interesting in knowing how much I’m using of the 92 MBytes of RAM and 1.4 MBytes of Flash that are available on the Raptor, but I’d kind of like to know what all the other numbers mean like STRING, FREEBLOCK, ASSEMBLY, BINARY_BLOB_HEAD, and APPDOMAIN_HEAD. Here is what shows up in the VS2013 output window when I download my app.
Thanks - Gene
Found debugger!
Create TS.
Loading start at 202dd578, end 2030ca0c
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: GHI.Hardware (4.3.7.10) Attaching deployed file.
Assembly: System (4.3.1.0) Attaching deployed file.
Assembly: CPF (1.0.0.0) Attaching deployed file.
Assembly: GHI.Usb (4.3.7.10) Attaching deployed file.
Assembly: GHI.Pins (4.3.7.10) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: MissionClass (1.0.0.0) Resolving.
GC: 2msec 350472 bytes used, 66755292 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 66755292 bytes
Type 17 (ASSEMBLY ): 35520 bytes
Type 1E (BINARY_BLOB_HEAD ): 314856 bytes
GC: performing heap compaction...
Ready.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll'
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'V:\Software\Gene\CPF\MissionClass\MissionClass\bin\Debug\le\MissionClass.dll', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'V:\Software\Gene\CPF\CPF\bin\Debug\le\CPF.exe', Symbols loaded.
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Usb.dll'
'Microsoft.SPOT.Debugger.CorDebug.12.dll' (Managed): Loaded 'C:\Program Files (x86)\GHI Electronics\NETMF v4.3 SDK\Libraries\le\GHI.Pins.dll'
The thread '<No Name>' (0x2) has exited with code 0 (0x0).
Program Started
