I have not loaded the beta yet. If it is going very well then I will load it.
I don’t have time fight a rough beta.
Mike BTDT
Mike BTDT
GHI test betas very throughly. You can almost say it is a full release if you want to
The only known issue is the one pointed out on the beta page.
Beta works just fine as far as I’ve tested.
I will switch over to beta today then
If you have access, I see no reason why not. The more testers the better.
Just loaded the beta onto my laptop and onto the domino.
Works perfectly
Don’t forget to replace your project references…
I did, Chris, otherwise it would not be loaded to the Domino
