The camera I got from GHI doesn’t seem to work at all. I tried the USB host and it also doesn’t seem to work.
I get the error
when I run the sample GadgeteerCamera app.
I created another small app that just has the USB host and the drive connected event wired up. It never fires.
I verified that the camera works when plugged it directly into the USB client. I also verified that the USB host works when I plugged it directly into the USB client. I’m able to use the camera and browse the files on the USB drive as verification.
Socket 3 just doesn’t seem to work. Is there any way to verify if this is a board issue? I don’t have a spare board to test.
I updated the firmware when I received the kit (1/13).
Below is program.cs and program.generated.cs. I’ve also attached a picture of my hardware configuration.
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace GadgeteerCamera
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
button.ButtonPressed += button_ButtonPressed;
camera.PictureCaptured += camera_PictureCaptured;
void camera_PictureCaptured(Camera sender, GT.Picture picture)
display.SimpleGraphics.DisplayImage(picture, 5, 5);
void button_ButtonPressed(Button sender, Button.ButtonState state)
PulseDebugLED();
camera.TakePicture();
// <auto-generated>
// This code was generated by the Gadgeteer Designer.
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
// </auto-generated>
using Gadgeteer;
public partial class Program : Gadgeteer.Program
// GTM.Module defintions
Gadgeteer.Modules.GHIElectronics.Display_T35 display;
Gadgeteer.Modules.GHIElectronics.Button button;
Gadgeteer.Modules.GHIElectronics.Camera camera;
//Important to initialize the Mainboard first
Mainboard = new GHIElectronics.Gadgeteer.FEZSpider();
Program program = new Program();
program.InitializeModules();
program.ProgramStarted();
program.Run(); // Starts Dispatcher
private void InitializeModules()
// Initialize GTM.Modules and event handlers here.
camera = new GTM.GHIElectronics.Camera(3);
display = new GTM.GHIElectronics.Display_T35(14, 13, 12, 10);
button = new GTM.GHIElectronics.Button(11);
