I have built a board with “EMX” module, and the board is on basis of "Cobra"
I want to test the UDP send. Where can I check the output of Ethernet?
the code is as follow:
using System.Net;
using System.Text;
using System.Net.Sockets;
using GHIElectronics.NETMF.Net.NetworkInformation;
namespace Okotemp5000_FEZ_Board
static int i=0;
static String msg = "Hello PC" +i;
static byte[] bytesToSend = Encoding.UTF8.GetBytes(msg);
static IPAddress DestinationIP = new IPAddress(new byte[] { 192, 168, 1, 56 });
static IPEndPoint DestinationEndPoint = new IPEndPoint(DestinationIP, 2000);
static Socket mySocket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
static void RunMe_1(object o)
msg = "Hello PC" + i;
mySocket.SendTo(bytesToSend, bytesToSend.Length, SocketFlags.None, DestinationEndPoint);
Debug.Print(new String(Encoding.UTF8.GetChars(bytesToSend)));
i++;
if (i == 100) i = 0;
Timer MyTimer_1 = new Timer(new TimerCallback(RunMe_1), null, 5000, 1000);
if (Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces().Length < 1)
Debug.Print("No Active network interfaces. Bombing out.");
Thread.CurrentThread.Abort();
Microsoft.SPOT.Net.NetworkInformation.NetworkInterface NI = Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0];
NI.EnableStaticIP("192.169.1.200", "255.255.255.0", "192.169.1.56");
Debug.Print("hello");
Debug.Print("The timer will fire in 5 seconds and then fire priodically every 1 second");
The parameter “bytesToSend” is what I want to send,
I can see something about “Debug.Print” In “output Window” of “Visual Studio” as follow:
hello
Hello PC0
Hello PC1
Hello PC2
Hello PC3
Hello PC4
Hello PC5
I find that my timer doesn’t run after about 5 second.
I waited about 10 seconds and saw timer run again, but only a few seconds, then timer stopped, after about 2 minutes, run again…
in "output " of “Visual Studio” I can see as follow:
Hello PC7
Hello PC8
Hello PC9
Hello PC10
Hello PC11
Hello PC12
Hello PC13
Hello PC14
I don’t know why?
Should the timer run every 1 second period?
How can I sure, if the parameter “bytesToSend” is sent successfully?
