How can I define a button per IO number?
I have “FEZ Spider Kit”.
I kown, if I use normal method just like as follow:
In “Program.gadgeteer” put the “button” symbol to the socket “4”.
and in “Program.cs” write codes:
        button.ButtonPressed += new GTM.GHIElectronics.Button.ButtonEventHandler(button_ButtonPressed);
        void button_ButtonPressed(GTM.GHIElectronics.Button sender, GTM.GHIElectronics.Button.ButtonState state)
            if (j == 0)
                j = 1;
                button.TurnLEDOn();
                j = 0;
                button.TurnLEDOff();
my question is, how can I use the IO number to define the button?
I don’t want to put the “button” symbol to the socket to define the button.
I kown the button pin is “IO33” and LED is “IO37”. I want to controll the individual pin.
You can use the core Output port, in your example you could do the following.
// Get the output port for pin 37. Set the initial state to false.
Microsoft.SPOT.Hardware.OutputPort pin = new Microsoft.SPOT.Hardware.OutputPort((Microsoft.SPOT.Hardware.Cpu.Pin)37, false);
// Write the state to the pin
pin.Write(true);
Actually for a button you want to use an InputPort. If you use it on a port that supports interrupts you can use the .Interrupt event, otherwise you’ll need a thread constantly calling .Read to check the state.
:slight_smile: InputPort, yes the other half of the question.
Use (Cpu.Pin) to convert either an int or the FEZ enumerated pin.
@ Skewworks -
thanks!!
If I define the “InutPort”, how can I define a Interrupt event for the IO37 pin?
           static InputPort  GPIO_Pin_4 = new InputPort((Cpu.Pin)GHIElectronics.NETMF.FEZ.FEZ_Pin.Digital.IO37, true, Port.ResistorMode.PullDown);
           // how can I define a interrupt event for the IO37 ???
InputPort is not an interrupt port. InterruptPort is how you define the “input” with an interrupt handler.
Yes as Brett said sorry I wasn’t more clear. InputPort if it does NOT support interrupt on the pin and constantly call .Read; InterruptPort if it DOES.
You can see what pins do and dont support interrupt on the product page for your device. Interruptible pins are marked with a *.
