I have parallel port lines that can either be Low or High, where high is pulled up to 3v. Setting a pin low is easy, but how can I release a pin, and let the pull up get it up to 3v, without actually setting the pin high (which would cause problems as a usbizi high is 3v3).
I’ve read that chapter of the ebook before asking - it doesn’t actually mention the impendence of the pin, nor this application, so I wanted to confirm.
