I have just received a Panda II Ultimate kit and attempted to load the example project code. However, upon its Build, I receive errors such as it can’t discern the object [FEZ_Components] and some methods.
I updated my firmware and have tried to install various SDK’s, but get an error for version incompatibility (see attached).
Lets also not forget that the firmware and SDK versions must be critically aligned. You said:
But the image is not about SDKs. You should tell us what version of the SDK you installed and what version your device shows - and any errors that came along the way.
