I am at the moment doing 1024 bit modpow (RSA) calculation in managed code and it is so sloooooooow, which it should be in manage.
It takes about 12 minuts to calc a 128byte long value with 128byte long exponent and modulus.
Does anyone have any faster way of doing it? I have tried to get BigInterger value type into RLP without any luck.
I realy need some help on this.
here is my test code:
private static bool RSA_TEST()
byte[] modulusArray = { 0xC1, 0x1A, 0x31, 0x2, 0x98, 0xD4, 0x33, 0xC4, 0xB7, 0xF6, 0x87, 0xDD, 0xE4, 0x9A, 0xFC, 0x14, 0xBA, 0xE, 0xA8, 0xE9, 0x8D, 0xAB, 0x57, 0x5C, 0xA7, 0xBB, 0xEE, 0x8B, 0x44, 0x7F, 0x82, 0xE2, 0x70, 0xFA, 0x25, 0xC2, 0x97, 0x54, 0x24, 0x28, 0x7F, 0x3D, 0xEC, 0x7D, 0x6F, 0xD3, 0xF2, 0xE, 0x9A, 0x29, 0x16, 0x4A, 0x40, 0x6C, 0xDD, 0x47, 0xF2, 0xE3, 0x59, 0x13, 0xBD, 0xA7, 0x5F, 0xDF, 0x52, 0x36, 0xD2, 0xBF, 0xC2, 0x76, 0xD2, 0x62, 0x58, 0x9A, 0x42, 0xCA, 0x43, 0xD4, 0xC5, 0xB6, 0x3, 0x19, 0x29, 0x0, 0x24, 0xBE, 0x1F, 0x4D, 0xE3, 0x2F, 0x6B, 0x15, 0x91, 0x91, 0xE7, 0x87, 0x3A, 0xF9, 0x9B, 0xC3, 0xAA, 0x12, 0x3A, 0x37, 0xC7, 0xE9, 0x39, 0xB5, 0xBE, 0xCA, 0x86, 0x58, 0xE9, 0xA1, 0xFE, 0x31, 0x47, 0x4E, 0x75, 0x33, 0x49, 0x5, 0x56, 0xAF, 0xA0, 0xF2, 0x11, 0xD1 };
byte[] exponentArray = { 0xA0, 0x5E, 0x8F, 0x2, 0x5E, 0xB6, 0x84, 0xB7, 0x76, 0x4D, 0xC2, 0x55, 0xA, 0x9A, 0x83, 0x1A, 0x64, 0x38, 0x8D, 0xDB, 0x65, 0xC9, 0x5E, 0x1F, 0xC, 0xE0, 0x24, 0x8, 0xAA, 0x90, 0xEB, 0xEA, 0x80, 0xC, 0xA7, 0x59, 0xE8, 0xDF, 0xAE, 0x13, 0xF0, 0xFD, 0x35, 0x60, 0x6F, 0x99, 0x20, 0x33, 0x5D, 0x9C, 0xED, 0x8, 0x1C, 0x19, 0xA5, 0xBA, 0xC, 0x47, 0x50, 0xA6, 0x25, 0xD5, 0x41, 0xD0, 0xFF, 0x90, 0x1F, 0xE4, 0x2A, 0x1C, 0x17, 0x13, 0xE3, 0x17, 0xC7, 0xE2, 0x80, 0xF5, 0xD3, 0xF9, 0xEF, 0x37, 0x54, 0xBF, 0x3B, 0x32, 0x8B, 0xF3, 0xCE, 0x6C, 0x25, 0x8A, 0x65, 0xDA, 0x0, 0x91, 0xAC, 0x83, 0x18, 0xA6, 0x36, 0x4C, 0x35, 0x5D, 0x7B, 0x81, 0xD2, 0xBB, 0x33, 0x35, 0x4C, 0x51, 0xB1, 0x26, 0xEC, 0xED, 0xE7, 0x4C, 0x62, 0x73, 0x76, 0x1B, 0x10, 0xFD, 0x41, 0xF2, 0x26, 0x1 };
byte[] seedArray = { 0x93, 0x45, 0xA1, 0x67, 0xD0, 0x3A, 0x4, 0x3C, 0xCB, 0x36, 0x3F, 0xD, 0x1F, 0x11, 0xF9, 0xAA, 0xF6, 0xF3, 0x19, 0xA3, 0xBC, 0x54, 0x27, 0x48, 0xE7, 0xFC, 0x6E, 0xA9, 0x5E, 0x3, 0xAC, 0x96, 0xCC, 0xD1, 0xD7, 0x9F, 0x97, 0x1E, 0x55, 0x14, 0xE0, 0xF2, 0xAA, 0x5, 0x67, 0xA5, 0x78, 0x42, 0xDC, 0xDF, 0x57, 0x5B, 0x8C, 0x98, 0xD9, 0xA0, 0x26, 0x18, 0xCD, 0x21, 0x8F, 0xF7, 0x88, 0xAE, 0xBF, 0x1D, 0xD4, 0xD7, 0x98, 0xC2, 0xC0, 0xEC, 0xF7, 0x6E, 0x73, 0xFD, 0xFA, 0xF9, 0xC9, 0xDA, 0xDB, 0x8B, 0x4C, 0x13, 0x87, 0x9C, 0xD6, 0xF8, 0x64, 0xF4, 0xFA, 0x99, 0x9C, 0xAB, 0xE7, 0xC6, 0x6A, 0x29, 0x79, 0xF, 0xF5, 0x26, 0xA7, 0xC4, 0x4E, 0xAA, 0x7C, 0xF5, 0x39, 0xD, 0x4E, 0x72, 0x72, 0xF7, 0xD7, 0xCB };
byte[] signedSeedArray = { 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x93, 0x45, 0xA1, 0x67, 0xD0, 0x3A, 0x4, 0x3C, 0xCB, 0x36, 0x3F, 0xD, 0x1F, 0x11, 0xF9, 0xAA, 0xF6, 0xF3, 0x19, 0xA3, 0xBC, 0x54, 0x27, 0x48, 0xE7, 0xFC, 0x6E, 0xA9, 0x5E, 0x3, 0xAC, 0x96, 0xCC, 0xD1, 0xD7, 0x9F, 0x97, 0x1E, 0x55, 0x14, 0xE0, 0xF2, 0xAA, 0x5, 0x67, 0xA5, 0x78, 0x42, 0xDC, 0xDF, 0x57, 0x5B, 0x8C, 0x98, 0xD9, 0xA0, 0x26, 0x18, 0xCD, 0x21, 0x8F, 0xF7, 0x88, 0xAE, 0xBF, 0x1D, 0xD4, 0xD7, 0x98, 0xC2, 0xC0, 0xEC, 0xF7, 0x6E, 0x73, 0xFD, 0xFA, 0xF9, 0xC9, 0xDA, 0xDB, 0x8B, 0x4C, 0x13, 0x87, 0x9C, 0xD6, 0xF8, 0x64, 0xF4, 0xFA, 0x99, 0x9C, 0xAB, 0xE7, 0xC6, 0x6A, 0x29, 0x79, 0xF, 0xF5, 0x26, 0xA7, 0xC4, 0x4E, 0xAA, 0x7C, 0xF5, 0x39, 0xD, 0x4E, 0x72, 0x72, 0xF7, 0xD7, 0xCB };
byte[] compareEncryptedData = { 0x3C, 0x84, 0xC8, 0xCB, 0x5F, 0xCE, 0xA6, 0x16, 0x59, 0x46, 0x85, 0x53, 0x2B, 0xCB, 0x4A, 0x98, 0xE0, 0xAA, 0x1D, 0x67, 0x7A, 0x1C, 0x1A, 0xD5, 0x31, 0xD5, 0x70, 0xC4, 0x85, 0x56, 0x98, 0xF3, 0x9B, 0x5B, 0x81, 0xE4, 0xBE, 0x17, 0x73, 0x3C, 0x5B, 0x75, 0xAC, 0x1F, 0xD1, 0x7B, 0x4B, 0xB6, 0x4A, 0xA5, 0xEB, 0x0E, 0x9A, 0x8A, 0x47, 0x54, 0xB1, 0xD7, 0x2A, 0xD8, 0xF3, 0x00, 0x94, 0xA4, 0xDF, 0x77, 0x11, 0x55, 0xCC, 0x17, 0x3A, 0xFB, 0x94, 0xAC, 0xDB, 0xFE, 0x4C, 0x43, 0x08, 0xDE, 0xCF, 0x7B, 0x49, 0xDA, 0x02, 0x77, 0x6E, 0xE4, 0x99, 0x27, 0x51, 0x36, 0xCF, 0x8E, 0xFA, 0xF1, 0xD0, 0x1A, 0x3C, 0xA0, 0x13, 0x71, 0x5A, 0xDE, 0x4F, 0xFF, 0x37, 0x5A, 0x5F, 0xEC, 0x75, 0x3A, 0x90, 0x09, 0x00, 0xA5, 0xBB, 0x70, 0xFD, 0x74, 0xF1, 0x2B, 0x2C, 0x61, 0xF5, 0x3F, 0x35, 0xFB };
byte[] key;
racedisplay.NETMF.Tools.BigInteger modulus = new racedisplay.NETMF.Tools.BigInteger(modulusArray);
racedisplay.NETMF.Tools.BigInteger exponent = new racedisplay.NETMF.Tools.BigInteger(exponentArray);
racedisplay.NETMF.Tools.BigInteger value = new racedisplay.NETMF.Tools.BigInteger(signedSeedArray);
value.Progress += new Tools.BigInteger.ProgressDelegate(value_Progress);
Factory.Instance.LogInformation(null, "Start RSA 1024bit calc");
key = value.modPow(exponent, modulus).GetBytes();
Factory.Instance.LogInformation(null, "Done!");
if (compareEncryptedData.Equals(key))
return true;
return false;
