Hi !
I just discovered that something wrong must have happened recently to the code section. Some of my code has disappeared, replaced by contents of my other projects.
For an example:
http://code.tinyclr.com/project/323/adafruit-motor-shield-driver/ which used to be an adafruit motor shield driver has kept the original picture, however all its contents has been replaced by http://code.tinyclr.com/project/318/dht22-rht3---temperature-and-humidity-sensor/
Same for http://code.tinyclr.com/project/340/fakedns---dynamic-web-server-redirection/
I didn’t change the contents myself. I realized this when someone else on the forum is trying to make a driver for the adafruit motor shield, I was just about to point him to the correct code, but couldn’t find it
Not sure I can find it back ! :-[
@ Joe, can you help fix it ? Thank you in advance !
