are these the same
http://www.robotshop.com/ca/dfrobot-single-relay.html
http://www.ghielectronics.com/catalog/product/192
No not the same pinout
i have the fez panda ,witch one should i use
Both would work, if you have GHI component shield or FEZ Connect then you need to get the the relay from GHI
i have http://www.robotshop.com/ca/ghi-component-shield-v2.html
so i need to get it form ghi i live in canda so how much will the shiping cost
[quote]Both would work, if you have GHI component shield or FEZ Connect then you need to get the the relay from GHI
[/quote]
what do you mean
Why are you posting the same question multiple times?! http://tinyclr.com/forum/1/3990/
This will only waste everyone’s time.
