I wonder if the boards in the following links support Bluetooth or not. (including FEZ products) what I mean support is that do these boards have like an expansion board so i can use it to connect bluetooth?
Haha, sorry I am a little bit of desperate because I need to do a project using one of the development boards to connect a bluetooth device…
so ~about the EMX module and ChipworkX, they don’t have this kind of Bluetooth Interface boards?
because the EMX development board and ChipworkX seem having more functions to me so I am just curious that is it possible to use The Bluetooth Interface board of FEZ with EMX or ChipworkX development boards?
The bluetooth module on the site is serial, not I2C.
Any board with a serial port supports bluetooth. All the boards on this site support serial thus bluetooth. I just connected my own bluetooth module to my Panda. But i’m about to start a new thread about that…
@ Errol yeah that I2C was just a side note in case stan didn’t want the BlueTooth GHI offers I know there are I2C chips out there…trying to preempt another question, ya know
I recommend that you use FEZ Cobra, FEZ Mini starter kit, FEZ Domino Starter Kit or FEZ Domino Starter Kit since it will be plug and play for you with that bluetooth board. Because they have these connectors at serial ports.
nevertheless, you can use this bluetooth board or any serial bluetooth bridge with any of the development boards we have. but that requires some hardware knowledge.
If you have to use FEZ Cobra, connect bluetooth TX to IO7 and the bluetooth RX to IO6. these IOs are used with COM4 on FEZ Cobra.
Take a look at FEZ Cobra’s brochure if you what to find these two IOs
The answer is ‘no’.
Because there are no JST3AA located on ChipworkX Board.
“The Standard JTAG Connector” that you’re referring to have nothing to do with Bluetooth Com port on the ChipworkX board.
take a look at distributor’s page: http://www.tinyclr.com/distributors/
may be the one that closest to you would be able to help you get what you want. there are eight of them in asia. And I know that at least in Singapore or Thailand have FEZ Domino and Bluetooth Board available.
