I attached the HD44780 (with display) to my Cerbuino Bee… Writing Hello World
to the display
Debug.Print(“Program Started”);
led7r.Animate(200, true, true, true);
LCD.Clear();
LCD.PrintString(“Hello WORLD”);
gives some odd chacarcters (see image)
(i tried on all three connectors \ the Display works fine m my Spider)
any ideas ?
bert
I think cerbuino is too fast for the display. This is good news!
We will update the driver with some delays.
What is the firmware version on your board?
@ Gus - @ Steven
Would the Cerberun not have the same problem (speed)> I thought the innerworks of cerberus and Cerbuino-bee are the same…
i put the latest firmwart on both (the same "Tinybooter 4.2.0.1 " LCD has problems on the bee, not on the cerberus
They should be identical. Have you tried a different socket?
@ Gus -
yes all 3 of them…
I am having this same issue on the Cerbuino bee on the current firmware.
has this bee fixed?
i have tried all three sockets.
I think a little delay is needed
Will you be updating the driver to do this soon?
or where do you think the delay needs to be?
@ Gus you are right. i added 1 ms sleeps between each write in the Putc and the SendCmd functions and it works like a champ
Can you try to sleep 0?
Thread.Sleep(0);
it works with Thread.Sleep(0); also
Can you please post your code showing where you added the delay? We are nto able to repro this on our end.
Putc and SendCmd is where i added the delays
using GT = Gadgeteer;
namespace Gadgeteer.Modules.GHIElectronics
/// <summary>
/// A simple character display module for Microsoft .NET Gadgeteer
/// </summary>
/// <example>
/// <para>The following example uses a <see cref="Display_HD44780"/> object to display "Hello World" on the character display.
/// First, we clear the screen and set the cursor to the top left corner.
/// Then, we display our desired text to the screen.
/// </para>
/// <code>
/// using System;
/// using System.Collections;
/// using System.Threading;
/// using Microsoft.SPOT;
/// using Microsoft.SPOT.Presentation;
/// using Microsoft.SPOT.Presentation.Controls;
/// using Microsoft.SPOT.Presentation.Media;
/// using Microsoft.SPOT.Touch;
/// using Gadgeteer.Networking;
/// using GT = Gadgeteer;
/// using GTM = Gadgeteer.Modules;
/// using Gadgeteer.Modules.GHIElectronics;
/// namespace TestApp
/// public partial class Program
/// void ProgramStarted()
/// display_HD44780.Clear();
/// display_HD44780.CursorHome();
/// display_HD44780.PrintString("Hello World");
/// Debug.Print("Program Started");
/// </code>
/// </example>
public class Display_HD44780 : GTM.Module
private GT.Interfaces.DigitalOutput LCD_RS;
private GT.Interfaces.DigitalOutput LCD_E;
private GT.Interfaces.DigitalOutput LCD_D4;
private GT.Interfaces.DigitalOutput LCD_D5;
private GT.Interfaces.DigitalOutput LCD_D6;
private GT.Interfaces.DigitalOutput LCD_D7;
private GT.Interfaces.DigitalOutput BackLight;
const byte DISP_ON = 0xC; //Turn visible LCD on
const byte CLR_DISP = 1; //Clear display
const byte CUR_HOME = 2; //Move cursor home and clear screen memory
const byte SET_CURSOR = 0x80; //SET_CURSOR + X : Sets cursor position to X
// Note: A constructor summary is auto-generated by the doc builder.
/// <summary></summary>
/// <param name="socketNumber">The socket that this module is plugged in to.</param>
public Display_HD44780(int socketNumber)
// This finds the Socket instance from the user-specified socket number.
// This will generate user-friendly error messages if the socket is invalid.
// If there is more than one socket on this module, then instead of "null" for the last parameter,
// put text that identifies the socket to the user (e.g. "S" if there is a socket type S)
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
socket.EnsureTypeIsSupported('Y', this);
LCD_RS = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Four, false, null);
LCD_E = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Three, false, null);
LCD_D4 = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Five, false, null);
LCD_D5 = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Seven, false, null);
LCD_D6 = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Nine, false, null);
LCD_D7 = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Six, false, null);
BackLight = new GT.Interfaces.DigitalOutput(socket, GT.Socket.Pin.Eight, true, null);
Initialize();
/// <summary>
/// This function will enable the display, clean it, and enter 4-bit mode.
/// </summary>
public void Initialize()
LCD_RS.Write(false);
// 4 bit data communication
Thread.Sleep(50);
LCD_D7.Write(false);
LCD_D6.Write(false);
LCD_D5.Write(true);
LCD_D4.Write(true);
LCD_E.Write(true);
LCD_E.Write(false);
Thread.Sleep(50);
LCD_D5.Write(true);
LCD_D4.Write(true);
LCD_E.Write(true);
LCD_E.Write(false);
Thread.Sleep(50);
LCD_D5.Write(true);
LCD_D4.Write(true);
LCD_E.Write(true);
LCD_E.Write(false);
Thread.Sleep(50);
LCD_D5.Write(true);
LCD_D4.Write(false);
LCD_E.Write(true);
LCD_E.Write(false);
SendCmd(DISP_ON);
SendCmd(CLR_DISP);
///<summary>
/// Sends an LCD command.
/// </summary>
private void SendCmd(byte c)
LCD_RS.Write(false); //set LCD to data mode
LCD_D7.Write((c & 0x80) != 0); Thread.Sleep(0);
LCD_D6.Write((c & 0x40) != 0); Thread.Sleep(0);
LCD_D5.Write((c & 0x20) != 0); Thread.Sleep(0);
LCD_D4.Write((c & 0x10) != 0); Thread.Sleep(0);
LCD_E.Write(true); Thread.Sleep(0); LCD_E.Write(false); //Toggle the Enable Pin
Thread.Sleep(0);
LCD_D7.Write((c & 0x08) != 0); Thread.Sleep(0);
LCD_D6.Write((c & 0x04) != 0); Thread.Sleep(0);
LCD_D5.Write((c & 0x02) != 0); Thread.Sleep(0);
LCD_D4.Write((c & 0x01) != 0); Thread.Sleep(0);
Thread.Sleep(1);
LCD_RS.Write(true); //set LCD to data mode
/// <summary>
/// Prints the passed in string to the screen at the current cursor position. Note: This function will move the cursor position after.
/// </summary>
/// <param name="str">The string to print.</param>
public void PrintString(string str)
for (int i = 0; i < str.Length; i++)
Putc((byte)str[i]);
/// <summary>
/// Sends an ASCII character to the LCD at the current cursor position. Note: This function will move the cursor position after.
/// </summary>
/// <param name="c">The character to display.</param>
public void Putc(byte c)
Thread.Sleep(0);
Thread.Sleep(0);
Thread.Sleep(0);
Thread.Sleep(0);
LCD_E.Write(true);
Thread.Sleep(0);
Thread.Sleep(0);
Thread.Sleep(0);
/// <summary>
/// Clears the screen.
/// </summary>
public void Clear()
SendCmd(CLR_DISP);
/// <summary>
/// Places the cursor at the top left of the screen.
/// </summary>
public void CursorHome()
SendCmd(CUR_HOME);
/// <summary>
/// Set the cursor to the passed in position.
/// </summary>
/// <param name="row">Row of the desired cursor position.</param>
/// <param name="col">Column of the desired cursor position.</param>
public virtual void SetCursor(byte row, byte col)
byte[] row_offsets = new byte[4] { 0x00, 0x40, 0x14, 0x54 };
SendCmd((byte)(SET_CURSOR | row_offsets[row] | col));
///// <summary>
///// Turns the backlight on.
///// </summary>
//public void TurnBacklightOn()
// BackLight.Write(true);
///// <summary>
///// Turns the backlight off.
///// </summary>
//public void ShutBacklightOff()
// BackLight.Write(false);
/// <summary>
/// Sets the module's backlight to the passed in value.
/// </summary>
/// <param name="bOn">True for backlight enabled, false for disabled.</param>
public void SetBacklight(bool bOn)
BackLight.Write(bOn);
Hello,
Would it be possible to have a plan to connect the LCD to the board ?
I started with Cerbuino.
thank you.
@ Matheo1010 - what do you mean?
Welcome to the community
