@ Alex Bilityuk - That means that the contrast needs a potentiometer or maybe half the voltage on the pin. You will need a voltage divider of some type to reduce the contrast.
This wonât work actually, not that easy anyway. There are 2 resistor on your board that act like a voltage divider. You can also solder a pot instead.
I experienced the same when using this board and ended up removing R1 and R2 and replacing them with something like a 10K and a 1K resistor respectively. The contrast and viewing and is now perfectly usable. This ended up giving a voltage on pin 3 of the LCD of something like 0.3V which worked well.
@ Alex Bilityuk - Check how much current the contrast pin on the display draws, just to be sure. Microcontroller pins donât provide much, but it might be enough.
Here we go guys! I want to thank all of you for advices and help! Finally i used break away headers and soldering, also i set the 3-rd pin to resistance regulator to set up a contrast manually!
