err - nope, and almost as soon as I hit post, I read:
I was hoping to avoid that as I use a Mac with XP on VirtualBox and while deployment all works fine, VirtualBox stops allowing the USB connection to forward to the VM as soon as you set the little dip switches on the Mainboard in preparation for the firmware upgrade.
Anyone met or even better resolved that problem? I don’t really want to inflict the entire Visual Studio stack on a friends PC just to update the firmware - probably once.
Sometimes, with Fusion, I have to manually connect a USB device to the virtual machine. Fusion does not always automatically forward new USB devices to the virtual machine.
In Fusion, there is a USB device menu item, under VM(?), for connecting and disconnecting devices to the VM.
For any other VirtualBox users out there, unlike ordinary usage of the Spider, to update the Firmware, you have to create an ‘open’ usb filter, rather than one specific to the device you plug in.
For your VM, go to Settings then select Ports, then USB, then click the blue dot to create an open filter that will catch all USB devices and pass them on to the VM.
THEN plug in your device with the dip switches already in the right position.
