I was trying this example out on my Cobra board.
[url]http://www.tinyclr.com/forum/10/866/#/1/[/url]
which worked fine. i have used MFDeploy and set a static IP , when it reboots it does indeed show the IP i set on the screen.
in that example when i comment out the DHCP section and un-comment out the static section it no longer works.
Any ideas why ?
What IP address did you set using MFDeploy ?
What IP did u use on this line ?
NI.EnableStaticIP("192.169.0.25", "255.255.255.0", "192.169.0.1");
What IP are you trying to connect to from the client (I assume the computer) ? Is it 192.169.0.25 ?
What is the IP addres of the client (assume your computer) ? Are both on the same network ?
the address i used on MFDeploy was 192.168.0.8
I used NI.EnableStaticIP(“192.169.0.8”, “255.255.255.0”, “192.169.0.1”);
I am using my computer to connect to it and my computer is 192.168.0.2
Both are on the same network. If i enable the DHCP it works fine. When i switch to static it dont not connect.
Can you ping 192.169.0.8 ?
The 169’s in the line above should be 168. Typo?
Typo or “copy paste” wonders
@ Todd Stone, Great Catch!
I cannot believe i missed that!!! I must have looked at that 10 times. I better get my eyes checked. Boy do i feel the fool now ;(
Changed it and works just fine now, thanks guys
