This occurred on the latest build, and the current RC
My solution has 10 projects thus far, when I make a change in any project 90% of the time I have to clean the project in which I made the change for the changes to get deployed to the device.
For example, I remove an operation from a method, I deploy and the operation remains. It’s not until I clean the project, that the operation is removed at deployment.
Here is a perfect example. I changed the numbers in the Debug.WriteLine from 123 to 222 (In the picture look at the code vs output window) and also added the int i = 4+4; Then I immediately Debugged, see the output window and the error about the variable i
If I clean the project and deploy again, then everything is good until I make another change.
