@ patc started with a standard Cerb40 that then ripped all tall components off it and used shorter ones. This is to allow the board to fit right under another PCB in an enclosure. When you think he is done, he went right into the firmware and modified it to add his own interops to handle time critical tasks. This is a perfect example how NETMF can still be used for low level and time critical tasks, which still enjoying the modern programming environment.
Really a great job, and a very fluent image processing.
The only thing for me is how to achieve that goal without having to go thru the firmware which is not an easy thing for someone like me, how does not have anymore the low level knowledge to do so, and come from the high level c# programming ?
As Jatc said, one month ago he did know nothing about NETMF insider, but will I know enough after one month on FIrmware insider ?..
@ patc - It is time to make it a little bit more consumer friendly, add/design some sort of reel/tape feeding mechanism and start offering it as a kit to DIYers.
Let me know if you need any help
