Have you installed the Visual Studio Integration for the Micro Framework as well?
There are seperate visx packages for VS 2012, 2013 and 2015 (downloadable from netmf.codeplex.com).
Not sure if the Gadgeteer core is already avail able for VS 2015.
Here’s what I have installed and such (image included) I’ve highlighted all the things that I’ve installed. Prior to each attempt, I uninstall all of those and start from the beginning. Error message is there too.
Could you explain more waht you mean by “Nothing is in VS”? Can you post a screensot of the “new Project” window?
How does the Version conflict Show up?
Please post screenshots/Output prints of the Errors you get.
There is no “Gadgeteer” project type under C# in VS2013 after a fresh install, by that I mean “nothing”
There is no version conflict that I know of. Installers do not complain when I uninstall all before re-attempting
There are no errors at this stage, only from VS2015, which I’ve given up on already. My problem now is to get this working in VS2013
What I find strange is that there are no VSIX files for Gadgeteer itself, only for NetMF - how are project types added for Gadgeteer? and I dont see any project or item templates in the VS folders.
The Gadgeteer templates are installed with the gadgeteer core.
For the Micro Framework SDK the VS plugin was seperated for easier updating.
If you have the microframwrok SDK and visx installed you should have new templates in VS like in attached Image.
I do not have gadgeteer installed, because I don’t Need (use) it.
If you create an NETMF Console Application you should be able to do some quick LED blinky test Project.
I have „SDK 2015 R1 Pre-Release 1" running on my PC with Visual Studio 2012 and VS 2013.
Be sure that you install the right versions of NETM (netmf-v4.3.2-SDK-QFE2-RTM.zip) and Gadgeteer Cor (NET Gadgeteer Core 2.43.1000). You get the right versions i f you go over the links of GHI Support .NET Micro Framework.
Well, I’m well on the way now, but still not satisfied.
I’m able to write to the Hydra using the Micro Framework, but I still dont understand fully how to set up the program correctly, so it’s slow and error prone. Are there any guides on how to work a Gadgteer mainboard using .Net Micro framework only?
