Hi All,
The answer to this may just be “no” but is it possible to do a gradient brush in the standard graphics library? (switching to the tinyclr.UI library is unfortunately not practical) the function is there in the source code, so I tried to do my own edits to it then import the new library which did one of 2 things:
a) broke the firmware, or
b) broke the resource manager.
All I did was add a gradient brush object then add some functionality to the FillRectangle method:
Brush:
public class GradientBrush : Brush
public Color startColor { get; set; }
public Color endColor { get; set; }
public GradientDirection direction { get; set; }
public GradientBrush(Color startColor, Color endColor, GradientDirection direction)
this.startColor = startColor;
this.endColor = endColor;
this.direction = direction;
public override object Clone()
return new GradientBrush(startColor, endColor, direction);
public enum GradientDirection
TopToBottom,
BottomToTop,
LeftToRight,
RightToLeft,
Graphics:
public void FillRectangle(Brush brush, int x, int y, int width, int height)
if (brush is SolidBrush b)
var rgb = (uint)(b.Color.ToArgb() & 0x00FFFFFF);
this.surface.DrawRectangle(rgb, 0, x, y, width, height, 0, 0, rgb, x, y, rgb, x + width, y + height, b.Color.A);
else if(brush is GradientBrush gb)
uint colorA = (uint)(gb.startColor.ToArgb() & 0x00FFFFFF);
uint colorB = (uint)(gb.endColor.ToArgb() & 0x00FFFFFF);
switch (gb.direction)
case GradientDirection.TopToBottom:
this.surface.DrawRectangle(colorA, 0, x, y, width, height, 0, 0, colorA, x, y, colorB, x, y + height, gb.startColor.A);
break;
case GradientDirection.BottomToTop:
throw new NotSupportedException();
break;
case GradientDirection.LeftToRight:
break;
case GradientDirection.RightToLeft:
break;
I really just need to figure out how to expose the internal DrawRectangle method - this would allow me to also do some less-Windows 95-looking buttons and such. At this point, the project I inherited has so much work built over the Graphics library that it would take an extraordinary amount of work to jump to the UI. Any pointers or ideas?
