I added the 12mm coin battery inside the encloser of my Cobra!
Now, I don’t have to look at the information clock that always start at 00:00:00 PM any more! ;D ;D
Nice!
I just set mine up to sync to NTP. It’s almost always connected to Ethernet, so it works out pretty well.
Do you have the power supply connecting to your Cobra all the time?
I think he means that he sync the clock on power up
Ah, my bad asking a question without thinking… :-[
Hahah, I do have it almost always plugged in, but I use this method to sync the system clock to NTP:
/// <summary>
/// Get DateTime from NTP Server
/// Based on:
/// http://weblogs.asp.net/mschwarz/archive/2008/03/09/wrong-datetime-on-net-micro-framework-devices.aspx
/// </summary>
/// <param name="TimeServer">Timeserver</param>
/// <returns>Local NTP Time</returns>
public static DateTime NTPTime(String TimeServer)
// Find endpoint for timeserver
IPEndPoint ep = new IPEndPoint(Dns.GetHostEntry(TimeServer).AddressList[0], 123);
// Connect to timeserver
Socket s = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
s.Connect(ep);
// Make send/receive buffer
byte[] ntpData = new byte[48];
Array.Clear(ntpData, 0, 48);
// Set protocol version
ntpData[0] = 0x1B;
// Send Request
s.Send(ntpData);
// Receive Time
s.Receive(ntpData);
byte offsetTransmitTime = 40;
ulong intpart = 0;
ulong fractpart = 0;
for (int i = 0; i <= 3; i++)
intpart = (intpart << 8) | ntpData[offsetTransmitTime + i];
for (int i = 4; i <= 7; i++)
fractpart = (fractpart << 8) | ntpData[offsetTransmitTime + i];
ulong milliseconds = (intpart * 1000 + (fractpart * 1000) / 0x100000000L);
s.Close();
TimeSpan timeSpan = TimeSpan.FromTicks((long)milliseconds * TimeSpan.TicksPerMillisecond);
DateTime dateTime = new DateTime(1900, 1, 1);
dateTime += timeSpan;
TimeSpan offsetAmount = TimeZone.CurrentTimeZone.GetUtcOffset(dateTime);
DateTime networkDateTime = (dateTime + offsetAmount);
return networkDateTime;
Thanks Chris ;D
