This version has fixed a lot of my problems and answered my wishlist but I am now getting pink borders around my TextBox objects, and can’t remove them! :’( (Occurs in Microosft emulation and FEZ Cobra 480x272 target) Running NETMF 4.1.0.6
Details of Fixes
Release Notes V 1.0.1
*** Always make sure to update your XML so it’s compatible with the latest version. ***
Button
Button now supports multiline text by using a newline operator \n
TextBlock
New properties added called BackColor (background color) and ShowBackColor (to turn it on and off).
Canvas
A new method was added called ClearAt(int index). In addition, most drawing methods now return an index so they can be cleared if need be.
MessageBoxManager
Responding to a MessageBox will properly close it before returning a value.
Going from showing a multiline message to a single line message will adjust the height properly now.
RadioButton
Setting a RadioButton’s IsSelected property to “True” in xml will not cause an Exception when loaded.
Glide Designer
Button tint color was off.
The characters <, >, &, ', " within a Text attribute will be replaced with their entity codes (<, >, &, &apos, ").
TextBox/PasswordBox
Fixed positioning when added to a DisplayObjectContainer.
