Hi - I’m using Spider with T35 display, and using Glide for the UI. Everything works well except for the slider, if I set the min value to 0 it works, anything else and knob jumps around. Hard to explain but the knob moves of off the line.
I need the slider to be between 50 and 100. Anyone countered this issue?
Sorry, I’m not setup to test this at the moment but I can suggest an easy work-around. Set the range from 0-50 and just add 50 to whetever you get back from it. I’m sure you know this but sometimes it helps to point out the obvious.
