Ref: http://www.ghielectronics.com/glide/example/3/
Target: Fez Cobra
NETMF: 4.1
I ran the ‘simple example’ as shown in the URL above.
On running in the debugger I got an Exception that 'Label is not supported?
I loaded the V1.0.0 Glide reference assembly
Can someone explain whats’ wrong? am I missing a step? as I’ve done everything on web page
Label support was removed in V1.0.0. You now use TextBlock.
The example has not been updated. I also saw a statement that if a Label found in the xml file it is converted to a TextBlock during parsing, but that was not implemented.
Thanks Mike
The Super Simple example was updated. This example uses a string for simplicity.
Label to TextBlock conversion only occurs if you paste XML containing a Label into the Glide Designer. Loading an XML file/string in Glide does not.
