I am having issues using a background image. I am viewing data from 2 sensors on screen fine but! when I add a background image the text is missing. Just the background image is showing. Any clues to why? Not a lot of docs on this out there.
Sorry, I should point out I am using the Cobra and the 3.5 screen full kit.
Just a guess (using it only for 1 day):
Did you add the image “on top” of the text?
I believe that the order the items are added is the order they are rendered. If I am correct, then it’s possible that your textblocks are loaded first, and then image on top of them.
Window also has a property called BackImage which will always be on the bottom if set.
