Hello,
I am a bit confused with NETMF Glide - updating UI elements. I have a separate thread (a Timer for instance) that periodically fired and the “main thread” handle them. Also I have a glide UI with some UI elements on it.
I would like to update these UI elements (TextBox) when the event is fired.
I have read many links: http://blogs.msdn.com/b/netmfteam/archive/2008/03/04/using-the-dispatcher.aspx
but I need some help to go on.
Following the link above I can only reach the Dispatcher with:
So I am forced to use the
```cs
public delegate Object DispatcherOperationCallback (
Object arg
Unfortunately I could not find any examples or samples.
Would you mind give me a guide how to use this?
Is there any different way to update the TextBox attribute?
Thank you very much for your help,
