I am [italic]NETMF 4.1[/italic] and GHI’s latest SDK. What I would like to do is Read/Write to an SD card inserted into my Panda II. While using the example from the beginners guide I went to use [italic]GHIElectronics.NETMF.IO[/italic] and VS2010 says it is missing. I reinstalled the GHI SDK and got the same problem. Any help would be appreciated.
You need to do 2 things
- add “using GHIElec…” in your code to tell the compiler you need it but this doesn’t add the library
- add the actual assembly to your project references. This is explained the book as well
Thanks again for your help.
