I think the following checks that are inside [em]public bool WriteRead(byte address, byte[] writeBuffer, int writeOffset, int writeLength, byte[] readBuffer, int readOffset, int readLength, out int numWritten, out int numRead)[/em] function are not needed and could be safely removed:
if (this.clockPin == Cpu.Pin.GPIO_NONE)
throw new ArgumentException("clockPin cannot be Cpu.Pin.GPIO_NONE.", "clockPin");
if (this.dataPin == Cpu.Pin.GPIO_NONE)
throw new ArgumentException("dataPin cannot be Cpu.Pin.GPIO_NONE.", "dataPin");
The following code ensure that those pins cannot be set to GPIO_NONE:
public Cpu.Pin ClockPin
get
return this.clockPin;
set
if (value == Cpu.Pin.GPIO_NONE)
throw new ArgumentException("value cannot be Cpu.Pin.GPIO_NONE.", "value");
this.clockPin = value;
public Cpu.Pin DataPin
get
return this.dataPin;
set
this.dataPin = value;
public SoftwareI2CBus(Cpu.Pin clockPin, Cpu.Pin dataPin)
if (clockPin == Cpu.Pin.GPIO_NONE)
if (dataPin == Cpu.Pin.GPIO_NONE)
@ iamin, I think they specifically need to check when they are are attempting WriteRead. There are cases (I believe) to have the variable be GPIO_NONE, sometimes.
@ John - Great! I would also suggest you to review other checks (in other functions) as well. For example:
if (writeOffset < 0)
throw new ArgumentOutOfRangeException("writeOffset", "writeOffset must be non-negative.");
if (writeLength < 0)
throw new ArgumentOutOfRangeException("writeLength", "writeLength must be non-negative.");
if (writeOffset + writeLength > writeBuffer.Length)
throw new ArgumentOutOfRangeException("writeBuffer", "writeOffset + writeLength must be no more than writeBuffer.Length.");
if (readBuffer == null)
throw new ArgumentNullException("readBuffer");
if (readOffset < 0)
throw new ArgumentOutOfRangeException("readOffset", "readOffset must be non-negative.");
if (readLength < 0)
throw new ArgumentOutOfRangeException("readLength", "readLength must be non-negative.");
if (readOffset + readLength > readBuffer.Length)
throw new ArgumentOutOfRangeException("readBuffer", "readOffset + readLength must be no more than readBuffer.Length.");
return this.bus.WriteRead(this.address, writeBuffer, writeOffset, writeLength, readBuffer, readOffset, readLength, out numWritten, out numRead);
The last line calls function that does the same checks again.
