An official announcement is coming soon, but, the non-Beta 4.2 SDK is up on the Support page.
http://www.ghielectronics.com/support/dotnet-micro-framework
Please let us know if you have any last second comments.
Thanks!
Installed GHI software and USB drivers installed just fine on my Win7 box.
Yea… I mentioned that from the last RC as well.
Roy
Is there a list of changes from the last RC to the release?
Roy
Still no love from Win8 for me.
And manual driver update is not working (for both WinUSB and NETMF_Interface folders).
@ mhectorgato - We will keep looking. So far all our windows 8 machines work fine, in expect for the boot loader. Hope fully a windows update will take care of this soon!
Speaking of that, do you have the latest updates? I am sure you do but just double check.
Added this page GHI Electronics – Where Hardware Meets Software
OK. I’m up to date with my updates.
Unfortunately, even with this last SDK version, I always have the IPAddress 0.0.0.0 problem with WiFi_RS21 module.
I have updated the firmware of my FEZ Spider, and created a new project. Here is my code:
if (!wifi_RS21.Interface.IsOpen)
wifi_RS21.Interface.Open();
if (!wifi_RS21.Interface.NetworkInterface.IsDhcpEnabled)
wifi_RS21.Interface.NetworkInterface.EnableDhcp();
NetworkInterfaceExtension.AssignNetworkingStackTo(wifi_RS21.Interface);
wifi_RS21.Interface.WirelessConnectivityChanged += new WiFiRS9110.WirelessConnectivityChangedEventHandler(Interface_WirelessConnectivityChanged);
wifi_RS21.Interface.NetworkAddressChanged += new NetworkInterfaceExtension.NetworkAddressChangedEventHandler(Interface_NetworkAddressChanged);
WiFiNetworkInfo[] ScanResp = wifi_RS21.Interface.Scan("MY_NETWORK_SSID");
if (ScanResp != null && ScanResp.Length > 0)
wifi_RS21.Interface.Join(ScanResp[0], "MY_NETWORK_PASSWORD");
void Interface_WirelessConnectivityChanged(object sender, WiFiRS9110.WirelessConnectivityEventArgs e)
Debug.Print("WirelessConnectivityChanged event!");
Debug.Print("Connected: " + e.IsConnected);
Debug.Print("IP Address : " + wifi_RS21.Interface.NetworkInterface.IPAddress);
void Interface_NetworkAddressChanged(object sender, EventArgs e)
Debug.Print("NetworkAddressChanged event!");
The output is:
Using mainboard GHI Electronics FEZSpider version 1.0
RS9110 firmware version Number is 4.4.5
RS9110 driver version Number is 4.4.5
Connected: True
IP Address : 0.0.0.0
Is there any change to solve this annoying problem?
I’m not able to drag & drop ENC28 module on designer with Cerberus. It says “- A required Library could not be found”. Is the Ethernet ENC28 compatible with Cerberus?
@ jango_jas - Yes it works with the cerb family - what is the missing library?
This is normal. Please see this http://wiki.tinyclr.com/index.php?title=Ethernet_ENC28_Module
In-Field update in next release! Sweet!
I just updated the Spider, Hydra and Cerb and all went as smooth as butter. Thank you GHI!
@ Gus, I know you guys have just released this, so no pressure just so you know someone is interested, I am looking forward to the code drop on codeplex of the latest updates to the firmware for the Hydra. My J-Link will be arriving on Monday/Tuesday so I am keen to play a bit.
I’m a bit late in the game, but Just updated my Spider to 4.2 and updated everything in VS. Converted my project from C# to VB and with the help of a recompiled Glide, it seems mostly back up and running
Great. Now to making some cool games
