Using the Cobra…customer complains that some GHI image/logo pops up when power is applied.
I don’t see it at all on my board (same software)–why? I do vaguley remember seeing it months ago when I started working with the boatrd. Is there some way to turn it off? I don’t remember doing that specifically…or perhap its presence or absence means something, in terms of the system?
Thanks, I see now how I could set it…but my current program does not (not have I ever before, to my recollection)…so why does the same program running on my board show no logo, but does on his? Seems quite strange.
[quote]You had erased your device at some point.
[/quote]
Gus:
Do you mean download a new user program? Of course, that is happening several times a week…the system software has also been downloaded…mine, not for at least a month or 2…the customer much more recent…is this logo something new?
If it was present long ago, I’m still not clear what I did to “erase” it. Would it be restored with a new operating system software load?
You can always make part of your normal start-up routine to check and replace the logo. That way if there’s a full wipe you don’t have to worry about it.
[quote]You updated firmware with complete erase?
[/quote]
Doesn’t the logo get restored if the new system software is reloaded (taking all the GHI provided steps to update BL & other netmf software)…its been a few months since I did that…did that erase & not restore the logo back then? I guess I’ll try a total reload to see what happens. I’m pretty sure my program itself never did anything to turn off the logo!
[/quote]
I guess so…I’m not sure how many ways there are to install the software…I thought I just followed the GHI instructions…Is the logo then gone for good ( usuing simple installation procedure, rather than by a running program). At least this might explain what happened
