We are excited to announce the release of the GHI Electronics NETMF SDK 2015 R1. We have spent many months making both major and minor updates to provide a very stable and user friendly SDK. These updates include but are not limited to; added G30, G80, G120E firmware, added product pin mappings to GHI.Pins, many fixes and improvements to G400 firmware, added PulseFeedback and reading/writing device configuration, along with improvements to the cellular radio module driver and several small bug fixes.
There are a few improvements that have not made their way into this 2015 R1 SDK. These will be added to the 2015 R2 release, scheduled for this coming November. A list of coming updates can be found at https://www.ghielectronics.com/docs/325/forthcoming-changes.
In this SDK we also include the 4.1 and 4.2 SDKs, however, please note that it is not recommended to use these SDKs nor are they officially supported.
@ Gary @ Gus you guys have been rocking, software and hardware releases by the bucket!!! Its very clear that summer vacations were cancelled this year at GHI.
last SDK G400 pre-release version were the same(if I am not wrong):
4.3.7.10 Firmware
4.3.7.7 Loader
Does it mean there is no change from last SDK pre-release, where the same versions were used?
So does it mean that it is not necessary to update G400 boards previously updated to last SDK pre-release?
@ mhstr - Correct. This release just changed the name from 2015 R1 Pre-Release 4 to 2015 R1 and combined the release notes. No firmware or other changes are present.
Can’t see anything in the release notes but I assume this has the fix for PPP that you discovered when not using the cellular modem, ie, other modems (SIM5320)?
