Ok, having a weird error. Could be win10, but not sure…
Have 4.3SDK (SDK-QFE2) installed. The VSIX says installed. I can create a new netmf console application and run it against the emulator, so that all seems consistent.
When installing the R1 pre-rel 3 package, no matter what options I un-select in Advanced, I am always prompted to locate the netmf SDK, and even when I do that I hit an error.
Plan:
[quote][2E78:4774][2015-06-27T11:33:56]i201: Planned package: sam_ba.2.12.exe, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[2E78:4774][2015-06-27T11:33:56]i201: Planned package: DfuSe_Demo_V3.0.3_Setup.exe, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2E78:4774][2015-06-27T11:33:56]i201: Planned package: DfuSe_Demo_V3.0.3_Setup_amd64.exe, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[2E78:4774][2015-06-27T11:33:56]i201: Planned package: NETMF_v4.2_SDK.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2E78:4774][2015-06-27T11:33:56]i201: Planned package: NETMF_v4.3_SDK.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2E78:4774][2015-06-27T11:33:56]i201: Planned package: _.NET_Gadgeteer_SDK.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[2E78:4774][2015-06-27T11:33:56]i201: Planned package: FEZ_Config.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[2E78:4774][2015-06-27T11:33:56]i201: Planned package: USB_Drivers_x86.msi, state: Absent, default requested: Absent, ba requested: Absent, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[2E78:4774][2015-06-27T11:33:56]i201: Planned package: USB_Drivers_x64.msi, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[/quote]
Then, it acquires the packages for SAM-BA and DFUSE, then:
[quote][2E78:4AD4][2015-06-27T11:34:07]i338: Acquiring package: DfuSe_Demo_V3.0.3_Setup_amd64.exe, payload: DfuSe_Demo_V3.0.3_Setup_amd64.exe, download from: https://www.ghielectronics.com/downloads/NETMF/SDK/DfuSe_Demo_V3.0.3_Setup_amd64.exe
[1484:3858][2015-06-27T11:34:27]i305: Verified acquired payload: DfuSe_Demo_V3.0.3_Setup_amd64.exe at path: C:\ProgramData\Package Cache.unverified\DfuSe_Demo_V3.0.3_Setup_amd64.exe, moving to: C:\ProgramData\Package Cache\676712FC14BC24F61C8DB296CC501E08CC58392E\DfuSe_Demo_V3.0.3_Setup_amd64.exe.
[2E78:4AD4][2015-06-27T11:34:27]w341: Prompt for source of container: WixAttachedContainer, path: C:\Users\brpound\Downloads\NETMF SDK.exe
[2E78:4AD4][2015-06-27T11:34:38]i336: Acquiring container: WixAttachedContainer, copy from: C:\Users\brpound\Downloads\MicroFrameworkSDK.MSI
[/quote]
The last line is when I select the netmf SDK msi package in the file select dialog box. As you can see from the plan, both the 4.2 and 4.3 SDKs are not expected, so I don’t know why it’s going into acquire mode nor why its failing. Any thoughts ?
Edit: the log then shows an error as it can’t extract the “expected” installer from the msi, as it’s expecting an exe that contains 4.3 msi.
