I would like to start using Glide, but am not sure how to get started.
I have a 7-inch display connected to my Cobra.
[ol]
What project type should I choose when creating the new project?
How do I calibrate my 7-inch touch screen?
Any other setup or configuration hints or tips for a newbie?[/ol]
I added a sub-directory called “Glide” and copied the contents of the Glide zip file into it (including the “be” and “le” sub-directories).
I added a reference to the Glide DLL in the “Glide” sub-directory.
I copied code from the first example into my Program.cs file.
I get this compile error:
Unable to copy file “C:\Documents and Settings\Jim\My Documents\Visual Studio 2010\Projects\Embedded Controller Projects\Cobra\Glide Test 1\Glide Test 1\Glide\be\LE\GHIElectronics.NETMF.Glide.pe” to “bin\Debug\LE\GHIElectronics.NETMF.Glide.pe”.
Could not find a part of the path ‘C:\Documents and Settings\Jim\My Documents\Visual Studio 2010\Projects\Embedded Controller Projects\Cobra\Glide Test 1\Glide Test 1\Glide\be\LE\GHIElectronics.NETMF.Glide.pe’.
Notice that it is looking for the “pe” file in a subdirectory with the path \Glide\be\LE". There is no such directory.
