Hi all,
I am using VS 2013 with GCC yagarto 4.7.2 toolchain.
The fez-hydra pk is on the git, apparently the entire pk is there not just the diff.
I could build the top level build.dirproj successfully.
But building the Solutions\FEZ_Hydra\TinyCLR.proj gave me the following errors (around the open ssl stuff).
If anyone has built the recent hydra pk successfully, please let me know.
The build error follows:
OpenSSL_PKCS11_signature.cpp:(.text._ZN24PKCS11_Signature_OpenSSL11VerifyFinalEP25_Cryptoki_Session_ContextPhm+0x5c): undefined reference to EVP_VerifyFinal' C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\lib\tmp_tinyclr.lib(OpenSSL_PKCS11_Token.obj): In function
PKCS11_Token_OpenSSL::Initialize()’:
OpenSSL_PKCS11_Token.cpp:(.text._ZN20PKCS11_Token_OpenSSL10InitializeEv+0x14): undefined reference to OPENSSL_add_all_algorithms_noconf' C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\lib\tmp_tinyclr.lib(OpenSSL_PKCS11_Token.obj): In function
PKCS11_Token_OpenSSL::Uninitialize()’:
OpenSSL_PKCS11_Token.cpp:(.text._ZN20PKCS11_Token_OpenSSL12UninitializeEv+0x20): undefined reference to EVP_cleanup' C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\lib\tmp_tinyclr.lib(ssl_err.obj): In function
ERR_load_SSL_strings’:
ssl_err.cpp:(.text.ERR_load_SSL_strings+0x3c): undefined reference to ERR_func_error_string' ssl_err.cpp:(.text.ERR_load_SSL_strings+0x40): undefined reference to
ERR_load_strings’
C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\lib\tmp_tinyclr.lib(legacy_support.obj): In function Crypto_Encrypt': legacy_support.cpp:(.text.Crypto_Encrypt+0xac): undefined reference to
EVP_aes_256_cbc’
legacy_support.cpp:(.text.Crypto_Encrypt+0xb0): undefined reference to EVP_EncryptInit' legacy_support.cpp:(.text.Crypto_Encrypt+0xb4): undefined reference to
EVP_EncryptUpdate’
legacy_support.cpp:(.text.Crypto_Encrypt+0xb8): undefined reference to EVP_EncryptFinal' C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\lib\InteropAssembliesTable.lib(CLR_RT_InteropAssembliesTable.obj):(.data+0x50): undefined reference to
g_CLR_AssemblyNative_GHI_Networking’
C:\dev\netmf\ghi\fez-hydra\tools\targets\Microsoft.SPOT.System.GCC.targets(325,5): error MSB3073: The command ““c:\dev\yagarto-20121222\bin…\arm-none-eabi\bin\ld.exe” -static --gc-sections --no-warn-mismatch --library-path=C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\lib --library-path=C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib -u ARM_Vectors -u _start --Map C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\bin\tinyclr.map --output=C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\bin\tinyclr.axf --script=C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\bin\tinyclr_scatterfile.ldf C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\obj\Solutions\FEZ_Hydra\TinyCLR\tinyclr_dat.obj C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\obj\Solutions\FEZ_Hydra\TinyCLR\allocator.obj C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\obj\Solutions\FEZ_Hydra\TinyCLR\tinyclr.obj -( C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SecurityPkcs11.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Core.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Hardware.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\InterruptHandler.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\HeapPersistence.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\IOPort.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Serialization.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Stream.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Debugger.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Debugger_full.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Diagnostics.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Graphics_Bmp.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Graphics.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Graphics_Gif.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Graphics_Jpeg.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\CorLib.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Serialization.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Graphics.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Hardware.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Touch.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Hardware_SerialPort.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Hardware_Usb.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_IO.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Net.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Messaging.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\CLRStartup.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\CRC.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\WireProtocol.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Hardware_OneWire.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SecurityPkcs11.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Update.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Messaging_stub.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Hardware_PWM.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\I2C.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\System_Xml.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\Xml.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_TimeService.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\SPOT_Net_Security.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\ANY_MEDIA\release\lib\RPC_stub.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\lib\tmp_tinyclr.lib C:\dev\netmf\ghi\fez-hydra\BuildOutput\ARM\GCC4.7\le\FLASH\release\FEZ_Hydra\lib\InteropAssembliesTable.lib -) -( “c:\dev\yagarto-20121222\arm-none-eabi\lib\libm.a” “c:\dev\yagarto-20121222\arm-none-eabi\lib\libc.a” “c:\dev\yagarto-20121222\lib\gcc\arm-none-eabi\4.7.2\libgcc.a” -) -( -)” exited with code 1. [C:\dev\netmf\ghi\fez-hydra\Solutions\FEZ_Hydra\TinyCLR\TinyCLR.proj]
Done executing task “Exec” – FAILED.
Done building target “BuildAXF” in project “TinyCLR.proj” – FAILED.
Done executing task “CallTarget” – FAILED.
Done building target “CoreSystemBuild” in project “TinyCLR.proj” – FAILED.
