GetHostEntry() Blocking
Is there any way to get around GetHostEntry() locking everything up if it can’t get a reply from the DNS server?
My testing device is plugged into a switch and uses fixed IP addresses. However, there is no connection to the internet. GetHostEntry() blocks UI updates and all other code.
Any suggestions would be helpful.
Hi Steve, is there any way to check if Internet is connected before making the call to GetHostEntry()?
I could ping Google’s DNS (8.8.8.8) to see if there is an active connection out to the internet. Is it possible to send a ICMP Ping in TinyCLR?
On what thread is the DNS lookup running?
You could try pinging the dns server first or is it that you can’t get an IP address either?
The call to GetHostEntry() is on a thread different from the UI and other functions. However, everything locks for about 10 seconds before an exception is thrown.
The IP address of the TinyCLR is set by the user, as well as the gateway and DNS addresses. Since it’s connected to a network switch embedded on the same circuit board the network appears active and has a link.
Pinging could be an option if TinyCLR supports the setup of a raw ICMP socket which I don’t believe it does. A timeout on the request would be best. I am not sure what would happen if the DNS was on the local router but the local network still didn’t have a connection to the internet. If the local router is just forwarding the request out to the internet but it can’t get there I don’t know if the result would be the same.
Ideally the GetHostEntry() call would not block all threads and have a reasonable timeout.
I will post a GitHub issue and see if there can be any resolution.
I added this to the GitHub issue, but repeat it here for this audience…
To be honest, this is a problem throughout the stack. Most networking calls block the interpreter, when one would hope that the interpreter keeps running, and only the calling managed thread gets blocked. It’s probably a pretty big mountain to climb to fix this because you would need to offload networking calls onto a dedicated native thread that then notifies the interpreter rather than blocking it from running at all. It’s a huge and often deal-braker issue in terms of keeping an app responsive, but it’s also probably a Big Deal to try to fix.
I’ve had the same issue–used to sync the RTC with an NTP server based on a DNS address. I haven’t found a way to fix the blocking problem, but I have noticed a few things that help.
  1. Make sure the network settings are all correct, especially the LAN DNS address and gateway values.
  2. Once a DNS is resolved to an IP, save the IP (if that’s an option) and just directly use that instead of parsing the string again.
  3. Throw a try catch around the parsing if not already, sometimes the connection is just weak depending on sorts of issues.
I agree with @mcalsyn though that I think it’s a deeper issue with a mountain of overhead to fix. Similar, holistic style blocking methods in other network classes such as ethernet. It’s kind of unfortunate :confused:
it fixed and will be release soon
