I got it to work.
Still got to tidy it up and fix the spelling mistakes but it works.
namespace DandTSoftware.Timers
/// <summary>
/// Midnight Timer Delegate for the event
/// </summary>
/// <param name="Time"></param>
public delegate void TimeReachedEventHandler(DateTime Time);
/// <summary>
/// Provides the means to detect when midnight is reached.
/// </summary>
public class MidnightTimer
#region Static variables
/// <summary>
/// Internal Timer
/// </summary>
private static Timer s_timer = null; // renamed from m_ to s_ to represent static
/// <summary>
/// How many Minutes after midnight are added to the timer
/// </summary>
private static int s_MinutesAfterMidnight = 0;
/// <summary>
/// Occurs whens midnight occurs, subscribe to this
/// </summary>
public event TimeReachedEventHandler TimeReached;
#endregion
#region Constructors
/// <summary>
/// Creates an instance of the Midnight Timer
/// </summary>
public MidnightTimer()
/// <summary>
/// Creates an instance of the Midnight Timer, which will fire after a set number of minutes after midnight
/// </summary>
/// <param name="MinutesAfterMidnight"></param>
public MidnightTimer(int MinutesAfterMidnight) : this()
// Check if the supplied m is between 0 and 59 mins after midnight
if ((MinutesAfterMidnight < 0) || (MinutesAfterMidnight > 59))
// if it is outside of this range, throw a exception
throw new ArgumentException("Minuets after midnight is less than 0 or more than 60!");
// Set the internal value
s_MinutesAfterMidnight = MinutesAfterMidnight;
#endregion
#region Public Methods
/// <summary>
/// Starts the Timer to fire a certain amount of Minutes AFTER midnight, every night (based on server time).
/// </summary>
/// <param name="MinutesAfterMidnight">How many Minutes after midnight do we start the timer? between 0 and 59</param>
public void Start()
// Subtract the current time, from midnigh (tomorrow).
// This will return a value, which will be used to set the Timer interval
TimeSpan ts = this.GetMidnight(s_MinutesAfterMidnight).Subtract(DateTime.Now);
// We only want the Hours, Minuters and Seconds until midnight
TimeSpan tsMidnight = new TimeSpan(ts.Hours, ts.Minutes, ts.Seconds);
// Create the Timer
s_timer = new Timer(timer_Elapsed, null, (int) tsMidnight.TotalMilliseconds, (int) tsMidnight.TotalMilliseconds);
/// <summary>
/// Restarts the timer
/// </summary>
public void Restart()
// (Re)Start
Start();
#endregion
#region Hanlders
/// <summary>
/// Standard Event/Delegate handler, if its not null, fire the event
/// </summary>
private void OnTimeReached()
if (this.TimeReached != null) // sanity checking
// Fire the event
this.TimeReached(this.GetMidnight(s_MinutesAfterMidnight));
/// <summary>
/// Executes when the timer has elasped
/// </summary>
/// <param name="sender"></param>
/// <param name="e"></param>
private void timer_Elapsed(object o)
// now raise a event that the timer has elapsed
OnTimeReached(); // swapped order thanks to Jeremy
// reset the timer
this.Start();
#endregion
#region Private Methods
/// <summary>
/// Obtains a DateTime of Midngiht
/// </summary>
/// <param name="MinutesAfterMidnight">How many minuets after midnight to add?</param>
/// <returns></returns>
private DateTime GetMidnight(int MinutesAfterMidnight)
// Let's work out the next occuring midnight
// Add 1 day and use hours 0, min 0 and second 0 (remember this is 24 hour time)
// Thanks to Yashar for this code/fix
DateTime Tomorrow = DateTime.Now.AddDays(1);
// Return a datetime for Tomorrow, but with how many minutes after midnight
return new DateTime(Tomorrow.Year, Tomorrow.Month, Tomorrow.Day, 0, MinutesAfterMidnight, 0);
#endregion
