Here’s the code where I think I’m targeting a single light:
(Again, I just modified the code I downloaded from the link in the original post.
if (true)
// init
//for (byte i = 0; i < 50; i++)
{ //c.WriteValue(i, 0xcc, (byte)r.Next(13), (byte)r.Next(13), (byte)r.Next(13));
c.WriteValue(8, 0xcc, (byte)r.Next(13), (byte)r.Next(13), (byte)r.Next(13));
I included three photos:
Photo 1) Wire from the lights: White: V+, Black: V-, Green - Data
Photo 2) Power Brick: White: V+, Black: V-
Photo 3) Putting it all together. Power: Lights White to Brick White, Lights Black to Brick Black, and Lights Data to that white wire leading to the Fez Panda II.
The White data wire is connected to SPI1.MOSI on the Fez board. I get lights and they all dance around. When I disconnect the data line, the lights freeze where they were.
Thanks…that helped some. Now instead of all 50 lights flickering, I only have about 4 or 5 lights.
I appreciate the help!
Since this is new to me, I appreciate the patience with my noobie questions and fumbling around.
Right now, I’m only going off the code sample provided at http://www.tinyclr.com/codeshare/entry/146. Are there other resources out there that discuss connecting the Fez and the G35 lights? I’ve come across lots of videos of what people have done using Fez to do this, but not necessarily how to do it for idiots like me.
Yes, they are. The first thing it does is sets the address for each light…and it’s during this phase that I have some lights turning on…when they should all still be off after completing the initialization phase.
This is where I wonder if I had a Logic Analyzer, would I be able to see what the Fez board is doing and compare that with original controller board?
