I keep getting this error when I try and run the push button to light led.
The code is exactly the same as Pete Browns Getting started.
The device is connected and running, once Iv no button push in the code.
Iv re-installed all the required packs. But it looks like Im still missing something.
Did you use the Visual Studio Gadgeteer template to create your project? If so, this includes the ProgramStarted() function in Program.cs. The call to this function is autogenerated and lives in Main() in Program.generated.cs. Do not alter this latter file. Program.cs should look something like the following:
using GT = Gadgeteer;
namespace GadgeteerApp1
public partial class Program
Access modules defined in the designer by typing their name:
e.g. button
camera1
Initialize event handlers here.
e.g. button.ButtonPressed += new GTM.MSR.Button.ButtonEventHandler(button_ButtonPressed);
// Do one-time tasks here
Woo fast reply. Tks
To answer your question the project is taken from the Gadgeteer template.
I just tried re doing the project from the start but I got the same error.
Does ‘redo’ mean adding Pete’s code? I suggest just creating the template and deploying without any code added. You should at least get the debug statement in the output window. If that doesn’t work, something is wrong with your VS template.
An unhandled exception of type ‘System.NullReferenceException’ occurred in Microsoft.SPOT.TinyCore.dll
Now Im even more confused because Iv used the template to do some simple graphics and it has worked.
So is the template wrong or is there another problem :
Did you have any issues when running through the SDK install(s) for Gadgeteer? The install app that GHI provided does a good job of checking to make sure you’ve got all the right pieces installed in the right order.
My bet is on “other problem”, but I’m not sure what. Maybe try reinstalling the SDKs.
Good Question
The install app did not work for me. It could not find the XML data.
So I installed manually. I also tried donloading and installing again but the app still would not work.
I got the setup files to work correctly, but still had the same problem.
However I noticed the namespace names were different on the program.cs and the generated.cs.
I corrected this problem. Now I keep ketting “led Not supported in dll file” and the same for button.
Im going to setup system on my laptop and see if that works. Ill let you know the result. ;D
System setup on laptop.
Im still getting exactly the same error.
I get the same error on both computers.
Over a week of programming ad I still cant get a simple program to work.
Anyone any ideas before I give up
Program is:-
namespace GadgeteerApp3
button.ButtonPressed += (s, ea) =>
led.BlinkOnce(GT.Color.Blue);
Can you make a new project with a very simple code, like this:
led.TurnBlue();
Beside, take a look on your MultiLED module, it has “XY*” and “" socket, make sure that the socket "XY” is connected to mainboard.
And also, usually when an exception is thrown, the program will stop at a breakpoint , what the breakpoint did you see?
Double click on “Program.generated.cs”, go to
[Code]
private void InitializeModules()
// Initialize GTM.Modules and event handlers here.
led = new GTM.GHIElectronics.MulticolorLed(8);
You will be received Null exception if don't have "led =new GTM.GHIElectronics.MulticolorLed(x)"
I tried your suggestion and it worked.
So I tried the blinking led. It dident work. I tried again and again and it worked.
Anyway to keep a long story short
Is it important to reset the Gageteer before you download software to it.
I found after writing a new project I needed to disconnect device. Reconnect download and when that failed reset device. Then providing there were no errors It would work.
is it possible this is a tight-loop problem where the debugger / deployment fails to connect to the board? thread.sleep(timeout.infinite) at the end of your app might help, but perhaps Gadgeteer already does that?
