Guys I need your opinion, is it possible to control the spider gadgeteer from PC Matlab?
Sounds complicated, any tutorials about the subject?
Yes.
In the past, I did an embedded project which gathered data, and sent it to a PC where it was processed by Matlab, and the results returned. We used an IP/TCP connection.
For further information, I suggest you check the Matlab documentation. TCP/IP - MATLAB TCPIP - Instrument Control Toolbox - MATLAB
Can you share part of your project with me so I would learn?
you could also use serial Create Serial Port Object - MATLAB & Simulink and https://www.ghielectronics.com/catalog/product/287
@ Jeff - I don’t poses that module, this is why I have to do it using the Ethernet module.
I only did the embedded side. Someone else did the Matlab side. On the embedded side, I used standard .NET sockets. Check the CodeShare for examples.
The Matlib documentation I referenced I believe had a link to sample code.
I can’t imagine how to begin at the embedded code =\
I suggest you go to the Support section of the forum and looks for documents and tutorials.
