What is the size of Gadgeteer.Interfaces.Serial internal read buffer?
Can I ask, why do you care?
And I actually am not sure there’s any buffer besides anything netmf and the hardware give.
@ pgierasi -
Hi, I hope this is the information you want to have:
https://www.ghielectronics.com/community/forum/topic?id=14346&page=2#msg145951
This is buffer in NETMF, 256 for TX 1024 for RX
For the open source Firmware the serial buffer sizes are
Cerberus : TX - 256 bytes, RX - 1024
Hydra : TX - 4096, RX - 4096
For the Premium firmware I am not sure.
@ taylorza, are those in NETMF or in Gadgeteer? Assuming netmf since they are different for the different platforms…
@ Brett - That is correct, the .NETMF serial drivers provide the buffering. To be more correct, the buffering is implemented in the PAL, each port just defines PLATFORM_DEPENDENT_TX_USART_BUFFER_SIZE and PLATFORM_DEPENDENT_RX_USART_BUFFER_SIZE if they want anything other than the default 512 byte buffer size.
