Does anyone know where I can get the 10 pin Gadgeteer compatible headers? Preferably through hole.
Thanks in advance!
Thanks in advance!
By connector, I’m assuming you mean the Gadgeteer socket?
One source is samtec.com. Through-hole part number should be SHF-105-01-L-D-TH. I use the surface-mount connectors, which are part number SHF-105-01-L-D-SM. Might be worth calling them to double-check, though, since the image for the TH part still shows the surface mount configuration.
One other thing to note…Samtec offers free samples, which can be a good way of ensuring you’ve got the right part.
GHI used to sell the sockets, but I don’t see them in the catalog any more.
They aren’t through-hole, but Ive used these:
29 cents each.
Here are TH:
I believe they are made by FCI. We buy SMD sockets from them, but I don’t have part numbers right now.
@ wbsimms - I was able to confirm that SHF-105-01-L-D-TH is the Samtec part number for the TH version of the socket. As it happens I have a handful that I got as samples when I was working on my IR module.
See the post previous to yours
Tip of the day. Get Samtec to send you a batch of 10 samples of both the TH and the SMD variants.
Thanks everyone for the help!
