Hi All, especially the GHI Team,
Problem Description:
[em]I need to remove the length of the Gadgeteer Connector Cables from my circuit. I have a project that requires High Speed and the stray inductance appears to be an issue.[/em]
I wonder about a Gadgeteer Header Terminal Block, a similar product to this but with a different Header Terminal, a Male Terminal instead of a Female Terminal.
URL: https://www.ghielectronics.com/catalog/product/405
Thanks All
All the Best
Chris
Samtec do female headers that would do what you need.
Thanks Dave,
I had a look and lots of 2 x 5 but cant see 1.27mm most are 2mm or above?
Chris
As Dave said, samtec do them, i have some 6 pin ones and i have used 10 pin ones in the past…
Thanks Guys, it was a good bit of info there!
I got these in the end: Proto Advantage - Dual Row 1.27mm Pitch 10-Pin Female Header to DIP-10 Adapter
Perfect! Exactly what I was after!
Chris
Thank You RobvanSchelven! +1
They are even better than I ordered! I will get a bunch of these next time!
All the Best
Chris
YW…Ideal for some solutions but there is no mechanical fixing from the housing. Those connectors are meant for board to board solutions, i guess. Fixing just comes from the connector pins.
