I’ll think about that as I really want this to remain as per the license on Turnkey where you can use for commercial use but no derivatives and it must show my details etc.
If you are interested in something commercial with modifications etc, we can talk? Send me a PM with your email.
I just received an engineering change notification from Newhaven on the NHD-7.0-800480EF-ATXV#-CTP display that I design this board around and there is a change to the LED backlighting voltage and current. The current design works with the 16V 60mA LED and the new one is 9.6V at 160mA so I need to check the design to see if there are any changes to the components. This new display is higher wattage but the add advantage of higher brightness, up from 200cd/m2 to 350cd/m2 which is a bonus.
Quick update. I got in some test panels today and the 7" LCD with the Gadgeteer connections looks great. This is using my FPC connection though to a custom G400 board but it would work just as well with the Gadgeteer sockets from a G120 or G400 based board.
When I get the enclosure for it in the next few weeks I’ll post some pictures of the final build. This is a lower cost NETMF version of my Android based logger. The Android one works great bit draws 8W whereas this NETMF G400 is only 2W so will run much cooler. Still got a bit of work on the software but I am chuffed with the 7" LCD and the ease with which I can port a lot of the Android code to it (the logic parts that is, the GUI is very different)
The Newhaven display looks even better in real life. It is a fraction of the price I pay for the one I use on the Android system.
Yeah, have to say that is a really crisp looking display. And the mounting is just plain beautiful. Having seen your and Justin’s metal work, and Ian’s woodworking all in one day, I just feel so … inadequate.
Software is free to download and it gives you prices in the software so you can check what each feature is going to cost.
Combined with 3D CAD software (for instance, Design Spark 3D is free) I can check fit and form before I design in their software. The LCD just slotted nicely into the 1mm deep cavity that I put in the rear to keep it in the right place.
With this you can design and build some really nice 1 off projects that don’t suffer from hand cut holes etc.
@ Dave McLaughlin - I just wanted to pass along a Thank You! I just built my own custom board for the New Haven 5" display. I used your LCD config settings. Seems to be working. It saved me a lot of time! Thanks so much for posting them!
:dance: :dance:
EDIT:
Well it was close.
I had to change the following from what you had in Replay #18.
Output Enabled is Fixed ----- True
The settings in reply #18 are for the 7" LCD. For the 5" one you need only change these but you seem to have it working with different sync settings. :think:
@ Dave McLaughlin - Strange. I tried your settings and it offset the image about 50 pixels to the right. For reference purposes and those who might pass this way in the future, here is the full settings list that is currently working for me:
Newhaven Display: NHD-5.0-800480TF-ATXL#-T
