@ yakov.morgen -
Both are no issue. But I have worked on G248 more than Seed accelerometers so I am ready to help you on G248 if I can.
on G400, G248 can work both hardwareI2C or softwareI2C. But if you want to see how softwareI2C work, I am also willing to help.
Frist, should take a look on how to change gadgeteer driver module
https://www.ghielectronics.com/docs/122/gadgeteer-driver-modification
then modify the G248 driver as below:
using GT = Gadgeteer;
using GTI = Gadgeteer.Interfaces;
using GHI.Premium.Hardware;
namespace Gadgeteer.Modules.GHIElectronics
// -- CHANGE FOR MICRO FRAMEWORK 4.2 --
// If you want to use Serial, SPI, or DaisyLink (which includes GTI.SoftwareI2C), you must do a few more steps
// since these have been moved to separate assemblies for NETMF 4.2 (to reduce the minimum memory footprint of Gadgeteer)
// 1) add a reference to the assembly (named Gadgeteer.[interfacename])
// 2) in GadgeteerHardware.xml, uncomment the lines under <Assemblies> so that end user apps using this module also add a reference.
/// <summary>
/// A Accel G248 module for Microsoft .NET Gadgeteer
/// </summary>
public class Accel_G248 : GTM.Module
//private GTI.I2CBus i2c;
/// <summary>Constructor</summary>
/// <param name="socketNumber">The socket that this module is plugged in to.</param>
static SoftwareI2CBus softwarei2cBus;
static SoftwareI2CBus.I2CDevice softwarei2cDevice;
const int SDA_PIN = 0; // need to change with your socket, at pin 8
const int SCL_PIN = 0; // need to change with your socket, at pin 9
public Accel_G248(int socketNumber)
Socket socket = Socket.GetSocket(socketNumber, true, this, null);
socket.EnsureTypeIsSupported('I', this);
//i2c = new GTI.I2CBus(socket, 0x1C, 400, this);
softwarei2cBus = new SoftwareI2CBus((Cpu.Pin)SCL_PIN, (Cpu.Pin)SDA_PIN); //add your sda, scl
softwarei2cDevice = softwarei2cBus.CreateI2CDevice(0x1C, 100);
WriteRegister(0x2A, 1);
private void WriteRegister(byte reg, byte value)
byte[] RegisterNum = new byte[2] { reg, value };
//i2c.Write(RegisterNum, 1000);
softwarei2cDevice.Write(RegisterNum, 0, RegisterNum.Length);
private byte[] ReadRegister(byte reg, int readcount)
int numWrite;
int numRead;
byte[] RegisterNum = new byte[1] { reg };
// create read buffer to read the register
byte[] RegisterValue = new byte[readcount];
//i2c.WriteRead(RegisterNum, RegisterValue, 1000);
softwarei2cDevice.WriteRead(RegisterNum, 0, RegisterNum.Length, RegisterValue, 0, RegisterValue.Length, out numWrite, out numRead);
return RegisterValue;
/// <summary>
/// Returns X acceleration.
/// </summary>
/// <returns>X acceleration</returns>
public int GetX()
byte[] test = ReadRegister(0x1, 2);
int X = test[0] << 2 | test[1] >> 6 & 0x3F;
if (X > 511)
X = X - 1024;
return X;
/// <summary>
/// Returns Y acceleration.
/// </summary>
/// <returns>Y acceleration</returns>
public int GetY()
byte[] test = ReadRegister(0x3, 2);
int Y = test[0] << 2 | test[1] >> 6 & 0x3F;
if (Y > 511)
Y = Y - 1024;
return Y;
/// <summary>
/// Returns Z acceleration.
/// </summary>
/// <returns>Z acceleration</returns>
public int GetZ()
byte[] test = ReadRegister(0x5, 2);
int Z = test[0] << 2 | test[1] >> 6 & 0x3F;
if (Z > 511)
Z = Z - 1024;
return Z;
/// <summary>
/// Obtains the X, Y, and Z accelerations.
/// </summary>
/// <param name="X"></param>
/// <param name="Y"></param>
/// <param name="Z"></param>
public void GetXYZ(out int X, out int Y, out int Z)
byte[] test = ReadRegister(0x1, 6);
Y = test[2] << 2 | test[3] >> 6 & 0x3F;
Z = test[4] << 2 | test[5] >> 6 & 0x3F;
if (X > 511)
X -= 1024;
if (Y > 511)
Y -= 1024;
if (Z > 511)
Z -= 1024;
You can compare with original file to see what I changed, then you will know how to change from hardwareI2C to softwareI2C, than do same way for Seed accelerometer.
Just a note here is, Accel G248 when read, need repeat start condition, so when read, should use WriteRead function.
I also have test code in NETMF without gadgeeter for G248, in case you want to test only G248.
