I was going crazy flipping back and forth looking through G400HDR_Breakout_SCH.pdf and G400_Module_Brochure.pdf trying to map to CPU Pins…
Well I bit my tongue and made a list… I’ll share if you need/want it.
I do not know of a way to post a text file in here so I will try Format as Code. I believe you can just copy and paste the text when you view this post.
Let me know if you find any errors…!!!
400HDR Socket types (As shown on G400HDR_Breakout_SCH.pdf)
Also using G400_Module_Brochure.pdf (latest that I know of)
(No reference Pin-Out) refers to G400_Module_Brochure? = Need to check
1 R Y LCD Red
2 G Y LCD Green
3 B Y LCD Blue
4 DI Power USB Client DP
5 Z Not Used
6 SU Y S (SPI) U (UART) Y (GPIO)
7 IU X I (I2C) U (UART) X (GPIO)
8 AI X A (Analog In) I (I2C) X (GPIO)
9 PU Y P (PWM) U (UART) Y (GPIO)
10 F F (SD Card)
All Sockets - Pin 1 VCC (3V3), Pin 2 +5, Pin 10 GND
X1 Red
Socket 1 Pin3 LCD Red0 - D400_171 PC11
Socket 1 Pin4 LCD Red1 - D400_172 PC12
Socket 1 Pin5 LCD Red2 - D400_173 PC13
Socket 1 Pin6 LCD Red3 - D400_174 PC14
Socket 1 Pin7 LCD Red4 - D400_168 PC15
Socket 1 Pin8 LCD VSYNC - D400_143 PC27
Socket 1 Pin9 LCD HSYNC - D400_144 PC28
X2 Green
Socket 2 Pin3 LCD G0 - D400_161 PC5
Socket 2 Pin4 LCD G1 - D400_162 PC6
Socket 2 Pin5 LCD G2 - D400_163 PC7
Socket 2 Pin6 LCD G3 - D400_164 PC8
Socket 2 Pin7 LCD G4 - D400_165 PC9
Socket 2 Pin8 LCD G5 - D400_170 PC10
Socket 2 Pin9 LCD BACKLIGHT? D400_138 PA28 (No reference Pin-Out)
X3 Blue
Socket 3 Pin3 LCD Blue0 - D400_152 PC0
Socket 3 Pin4 LCD Blue1 - D400_153 PC1
Socket 3 Pin5 LCD Blue2 - D400_154 PC2
Socket 3 Pin6 LCD Blue3 - D400_155 PC3
Socket 3 Pin7 LCD Blue4 - D400_156 PC4
Socket 3 Pin8 R3 0 - D400_119 PC24 / LCDDISP (No reference Pin-Out)
R4 DNP - D400_166 ( JP1_7, PC29 / LCDDEN) - LCD Enable
Socket 3 Pin9 LCD CLK - D400_145 PC30 - LCD CLK
X4 DI [As shown on USB_Client_DP_Module_SCH.pdf]
Socket 4 Pin3 D400_149 [STAT] - ( JP2_13, PD5 ) (No reference Pin-Out)
Socket 4 Pin4 D400_196 [USB_DEVICE_D-] - ( JP12, USB_A_N, USB1 HOST/CLIENT D- )
Socket 4 Pin5 D400_194 [USB_DEVICE_D+] - ( JP1_4, USB_A_P, USB1 HOST/CLIENT D+ )
Socket 4 Pin6 D400_137 [UD_VBUS] - ( JP2_17, PA27 ) (No reference Pin-Out)
Socket 4 Pin7 D400_139 [JACK_DET] - ( JP2_16, PA29 ) (No reference Pin-Out)
Socket 4 Pin8 D400_115 [No connection] ( JP2_26, PA30/TWD0 ) - I2C SCL
Socket 4 Pin9 D400_116 [No connection] ( JP1_26, PA31/TWCK0 ) - I2C SDA
X5 Z (Not Used)?
X6 SU Y
Socket 6 Pin3 D400_101 ( JP2_31, PC31/FIQ )
Socket 6 Pin4 D400_98 ( JP1_34, PA5/TXD1 ) - COM3 TXD/CANTX1
Socket 6 Pin5 D400_99 ( JP2_34, PA6/RXD1 ) - COM3 RXD/CANRX1
Socket 6 Pin6 D400_100 ( JP1_33, PC22/LCDDAT22 ) (No reference Pin-Out)
!! Brochure shows PA21 and PA22 - Both as SPI1 MOSI
Socket 6 Pin7 D400_178 ( JP1_5, PA22/SPI1_MOSI )
Socket 6 Pin8 D400_176 ( JP1_1, PA21/SPI1_MISO )
Socket 6 Pin9 D400_175 ( JP2_9, PA23/SPI1_SPCK ) - SPI1 SPCK
X7 IU X
Socket 7 Pin3 D400_136 ( JP1_18, PA26 ) (No reference Pin-Out)
Socket 7 Pin4 D400_118 ( JP1_25, PA10/DTXD ) - COM1 DTXD/CANTX0
Socket 7 Pin5 D400_117 ( JP2_23, PA9/DRXD ) _ COM1 DRXD/CANRX0
Socket 7 Pin6 D400_104 ( JP1_31, PB12/AD1/PWM1 ) - AD1
Socket 7 Pin7 D400_ No connection
Socket 7 Pin8 D400_115 ( JP2_26, PA30/TWD0 ) - I2C SCL
Socket 7 Pin9 D400_116 ( JP1_26, PA31/TWCK0 ) - I2C SDA
X8 AI X
Socket 8 Pin 3 D400_158 ( JP1_9, PB14 / AD3 / PWM3 ) - AD3
Socket 8 Pin 4 D400_159 ( JP2_11 , PB15 / AD4 ) - AD4
Socket 8 Pin 5 D400_114 ( JP1_27, PB16 / AD5 ) - AD5
Socket 8 Pin 6 D400_110 ( JP1_29, PB17 / AD6 ) - AD6
Socket 8 Pin 7 No connection
Socket 8 Pin 8 D400_115 ( JP2_26, PA30 / TWD0 ) (I2C SCL / SPI1 NPCS3 ) - I2C SCL
Socket 8 Pin 9 D400_116 ( JP1_26, PA31 / TWCK0 ) (I2C SDA / SPI1 NPCS2 ) - I2C SDA
X9 PU Y
Socket 9 Pin 3 D400_96 ( JP1_35, PB18 / IRQ / ADTRG ) - IRQ/ADTRG
Socket 9 Pin 4 D400_200 ( JP1_3, PA7 / TXD2 ) - (COM4 TXD / SPI0 NPCCS1) - COM4 TXD
Socket 9 Pin 5 D400_167 ( JP2_10 , PA8 / RXD2 / SPI1_NPCS0 ) - COM4 RXD
Socket 9 Pin 6 D400_132 ( JP1_20, PC26 ) (No reference on Pin-Out)
Socket 9 Pin 7 D400_105 ( JP2_29 , PC18 / LCDDAT18 / PWM0 ) - PWM0
Socket 9 Pin 8 D400_130 ( JP1_19, PC21 / LCDDAT21 / PWM3 ) - PWM3
Socket 9 Pin 9 D400_133 ( JP2_19, PC20 / LCDDAT20 / PWM2 ) - PWM2
GND Reset button NRST
GND LDR1 button PA4
GND LDR0 button PA24/LDR0
