I believe I found an issue with the G400D and setting a static IP Address with leading zeros.
If you set the IP address as “10.0.26.18” it works fine, but if you set it as “010.000.026.018” it then reports it’s IP address as “8.0.22.16” see sample program below
This was not the case with ChipworkX and MF v4.1.
static EthernetBuiltIn eNet = new EthernetBuiltIn();
eNet.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(eNet);
eNet.NetworkInterface.EnableStaticIP("010.000.026.018", "255.255.255.0", "0.0.0.0");
eNet.NetworkInterface.EnableStaticDns(new string[] { "0.0.0.0", "0.0.0.0" });
Debug.Print("IP Address: " + eNet.NetworkInterface.IPAddress);
Debug.Print("Subnet Mask: " + eNet.NetworkInterface.SubnetMask);
Debug.Print("Gateway: " + eNet.NetworkInterface.GatewayAddress);
System.Threading.Thread.Sleep(-1);
