G400D Ethernet reference design?
Is there any reference design for the Ethernet port on the G400D?
I have an RJ45 with built in magnetics and need to know if I need to include the termination resistors and capacitors next to the connector?
ie, is the exposed TX+, TX- etc just direct from the CPU or does the G400D module contain the termination components?
Thanks Andre,
Looking at the J11D schematic there is no termination other than for the transformer center tap so I can go ahead and wire up the connection on my board.
Cheers.
