dear sir,madam
at least i had 2 incidents on handling usb storage media. :-[ :-[
there have been 2 cases:
- after multiple write during sqlite database operations the file-system has been damaged. Sometimes the device will be restarted
by the end-user. in error-case the database can be only read, any write request leads to an i/o exception. - I use sqlite database and additionaly I handle temporary storage of files up to 1meg.
the problems are as follows:- I assume if there is a database write operation and a file write operation at the same time the framework crashes internally without restart
and the fault that file system including all files and folders got lost! - write operation of large file onto usb storage device work with success (programatically). also loading existing files on storage media
and any checks are successfull.
any file-system check on a following restart failed. in spite of file.flush the data have not been really written.
usage: sandisk ultra fit usb 3.0
runtime/framework 4.3: netmicroframework 4.3.8.1 latest ghi firmware everywhere
any hints would be fine.
KR
Herbert
